Question about Maytag Appliances Over-the-Range Microwave Oven
Maytag Over The Range Microwave #MMV4184AAW//No Power
I removed the overhead light bulb on the left side and it came out in two pieces. I have to go and get a new one today, however the problem is the unit has no power at all. Checked the plug and breaker, nothing wrong. Does this unit have a safety built in that when there is a light bulb missing that it acts like a safety switch and won't come back on till the bulb is replaced?
  • 958 Answers
No Mdicker, there is no safety thing that it would not run if there is a bulb missing or not installed.
i'm guessing that there is a fuse inside that went out when the bulb broke.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
  • francis rivero Oct 02, 2008
    hello Mdicker,
    how's your microwave?...have you replaced the bulb? is it heating up now?...keep me posted please.
    wish you all the best,
    drcool
Tip
Change light bulb GE MOnogram Advantium Microwave oven
I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved
on Feb 17, 2009 | GE Monogram ZE2160SF Convection /...
No socket for bulb on left side of oven
The oven cavity lamp is hidden up on top. You have to unplug the oven and remove the single piece top/side cover to get at it. Typically, you have to take out screws on the back of the oven along the top and side edges. Sometimes there are also screws in the sides and rarely along the bottom edge. Once you get these screws out, pull the cover back about 1/2" and lift it away. Look for a standard appliance light bulb right over the holes in the oven cavity ceiling or wall where the light normally shines in.
Dec 30, 2010 | Maytag MMV4203D 1100 Watts Microwave Oven
Overhead microwave light won't turn off after replacing bulbs
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for only $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Dec 17, 2010 | Whirlpool Microwave Ovens
How do you change the light bulb on an electrolux built in microwave ?
It is indeed straightforward but it requires removing the 4 phillips head screws that hold the trim kit on. Then you need to remove it from the cabinet (along with unplugging the cord.) Once that is done you will need to remove the 4 black phillips head screws along the bottom part of each side, 2 phillips from the left rear and 2 security T20 screws from the right side. I found that removing the 2 screws holding the bracket on the capacitor and the front allowed me to move the light housing enough to get to the bulb. In my case the bulb had unscrewed itself. I am not a big fan of the engineering associated with this model or the labor that assembled it.
Oct 23, 2010 | Electrolux Over-the-Range Microwave
Over the Range Light Bulb
"Appliance Parts Pro's" web-site bet they will have it or can get you the exact thing you need
Jul 18, 2009 | Maytag MMV4205 Microwave Oven
Sharp carousel non functional overhead light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 31, 2008 | Sharp R-1480 Microwave Oven
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
Maytag Appliances Over-the-Range Microwave Oven Logo
456 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
