Uniden DECT 6.0 Cordless Phone ID Logo
diana Posted on Nov 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot get a dial tone on phone. say's it is on hold
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Jan 19, 2012
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428271
Points
622693
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only direct you to select it from the list beginning here to download a copy of the manual.
1 Related Answer
Dave Ellis
  • 84 Answers
  • Posted on Mar 04, 2009
SOURCE: Uniden Dect2080 with 5 cordless phones
try using the telephone cord and jack from the phone that is working with the phone that is not working, if it now works the problem is the jack you were using or the phone cord. If that doesn't solve the problem, unplug the AC adapter and the phone cord for the non-working phone and let it sit for a couple minutes, plug them back in then try to make a call.
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • 2helpful
    I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
    Resetting the voice message waiting indicator
    When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
    voice messaging system, you can manually reset it back to the "No messages waiting" state.
    1. Press and hold FiND on the base for five seconds.
    Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
    2. A beep sounds and the message alert tone is reset.
    Changing the dial mode
    Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
    1. Press MENU/SELECT.
    2. Select the Global Setup menu, and then the Dial Mode submenu.
    3. Scroll to highlight Pulse.
    4. Press MENU/SELECT. You will hear a confirmation tone.
    If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
    Finally for future ease of use, here is a link to the user manual were I copied the above information from:
    http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
    1helpful
    Have a 1976 Mickey Mouse push button phone. I get a dial tone, but not able to dial out
    This may be something as simple as REVERSING the line wires or a bad tone pad. Some pre 1980's tone pads didn't have polarity guard (EPG) and that's what we used to restrict dialing on touch tone lines (poor man's dialing restriction).
    You can open up the jack the phone plugs into and reverse the red and green wires, or open up the phone and do the same thing. If it were my choice, I'd reverse the jack. If that doesn't fix it, pry off the faceplate cover over the dial, read the part number on the right side of the tone pad and post back. I'm sure I have an equivalent in the warehouse (outside of my 2 TT Mickey's) that I can give you a price on.
    Carl
    I have a line phone. I cleaned the top of it and must have touched something because I now have no dial tone. I recently purchased 2 Uniden no line phones no dial tone on them either. The model # is 1818...
    Try reset the phone in question, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
    How do i transfer a call to another extension?
    Unless your phone is connected to a TAW-848 or higher, your extensions are numbered 101-124 maximum, or 21-36. Try going to any phone but the main one and dialing either 101 or 0 and look at the display. You'll figure out your 3-digit extensions. Now just press TRANSFER and dial that 3-digit number. The outside call is put on hold when you press transfer, so there's no need to use the HOLD button.
    As an alternative, you can press HOLD, putting the outside line on hold, and dial the 3-digit number into the intercom dial tone and announce the call for line number x. Or, dial the page code 330 and announce to all phones for the person to pick up line x.
    Carl
    5helpful
    2answers
    Need to change phone back to tone dialing
    Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
    9helpful
    5answers
    Pulse and tone
    in GE:
    TONE/PULSE DIALING
    This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
    touch-tone use. To set to tone or pulse dialing:
    1. Press and hold the program button for two seconds. You will hear a beep.
    2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
    3. Press the program button again. You will hear a confirmation tone.
    2answers
    Radio shack phone c-4210
    for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
    6helpful
    4answers
    Ge 900 MHz cordless phone set on rotary dialing
    Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
    Top Uniden Lands Phones Experts
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
