Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint Ultima completely dead, no problem history
    President:
  • 2,712 Answers
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. You can also visit this website for more troubleshooting details:
http://www.repairclinic.com/0088_11_1.asp#Level1_1
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Sep 28, 2008
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
the mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Nov 10, 2014 | Hotpoint Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Machine does not clean clothes the machine seems to work ok but the washing feels stiff and there is sedment on the washing the machine is a hotpoint ultima 18 months old.
Try cleaning out the dirty water pipe. Mine was completely blocked up with scale and soap powder. We used a coat hanger and went from the out side as well. The water now pumps out completely without leaving any left under the drum
May 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt761 working fine one day, the next just dead as a dodo, no lights, noises,nothing, tried changing fuse, still nothing
These units have a cut out swich, that is thermaly activated, unplug and check the back of the machine, you may find a red reset button, i havent looked at this model, so it could be hidden under a backplate, also is may only have the replacable cutout, you will recognise it by its button sized, silver in colour, with two leads pushed onto its spades.
Warning if it was this then it overheated, so clean all fillters befor operation.
Sep 22, 2009 | Hotpoint Ultima WD72 Front Load...
Changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf860
Manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
There is a helpline number listed near the end to give you further help
Mar 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860
when the machine was flashing door this was telling you that either the door was not shut properly, try it again, or the interlock switch was faulty, chances are its probably shorted out and blown the circuit board, take care and remove the board to check for signs of blowing, if no signs then i would replace the interlock and start from there, ps i am a retired engineer and have had the same machine myself
Sep 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
