Question about Cameras
Function buttons won't work, display might flash up for a second but not long enough to make any changes. Only takes pictures maybe every 5 tries as a result.
    President:
  • 2,712 Answers
First try a hard reset - Remove batteries and SD card. Wait about 10 minutes and try again. If the issue is still there, it could be some faulty battery contacts or firmware issue.
Try to clean the battery contacts in the camera using isoproyl alcohol. You can also try scratching the contacts a bit with a jeweller's screw driver and see if it works.
If it is a firmware issue, then you may need to take it back to the store to get the firmware reinstalled or upgrade from the manufacturer's website (they usually give instructions on how to do this on the website.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Sep 28, 2008
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
The flash on my camera is not working!!!!
If the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Hope this one helps.
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Menu and display buttons do not function
One quick question. Is the camera taking photos?? when you try to transfer the photos to computer , are the photos fine or there are some Black photos??
Regard's
Manoj Goyal, INDIA
+91-9214988557
Dec 03, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Changing the clock
Try this, which works for most Pioneer car radios, they say.
Turn key to ignition on or accessories position, turn radio off. A time should be displayed, and maybe it is incorrect.
Press the Function key and hold it for 3 seconds and the hour will flash. Use either the up/down or the left/right button to change the time. When finished, I think you push the Function key again.
Nov 08, 2007 | Pioneer DEH-235 CD Changer
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Jun 11, 2007 | Casio MS-80TV Scientific Calculator
Cameras Logo
80 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
