My trial of adobe 9 pro will not convert to word. It stops when saving pages
  • 1 more comment
  • anniedonais Sep 28, 2008
    WORD 2003
    ADOBE ACROBAT 9 PRO EXTENDED
    DOWNLOADED TRIAL VERSION OF 2007 WORD ALSO
    I got rid of 2007, because it was a trial.
    But it still did not convert.
    I might have forgot to mention that what I am trying to convert has bar codes on them.
    I could just get a bar code generator, but I'm not sure what bar code format they used.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What version of Word do you have?
    Is the Adobe Acrobat that you are using?
  • 2,794 Answers
You need to have only one version of Word in your computer.  Otherwise Adobe is going to have trouble converting it.  Word 2007 is completely different that 2003.
Posted on Sep 28, 2008
  • Tim Babcock
    Tim Babcock Sep 28, 2008
    Got a sample of what their using?
    You will need a font for it. I can find you one once I have a look at it.
Cant open qpw file
You can check on the link below were you can download an converter for Quattro Pro spreadsheettrans.gif?cver=2.13.0068.3.
Note: This is an third party program (Non Microsoft program), it might help you.
http://www.pcworld.com/downloads/file/fid,3825-order,1-page,1-c,spreadsheet/description.html
Else you can also try to downloading a trial version http://www.corel.com, open your old files, save them in Excel format
Feb 07, 2013 | Borland Quattro Pro 5.0 Full Version for...
Tip
How to import M2TS files to Adobe Premiere for editing
In Sep. 23, 2008, Adobe released Adobe Premiere Pro CS4, and in October of the same year, it released Adobe Premiere Elements 7.0, both the two programs include AVCHD support (but not in the trial version of CS4). It is good news for people to see that via the two versions and the later ones, they are able to edit their footages shot by a Sony HDR-SR10, or other AVCHD camcorders, which have .mts or .m2ts file extensions. The thing is that some people already have a Premiere Pro CS3, Premiere Elements 4.0, or even older versions, they are not willing to spend money for upgrading or purchasing, and then what would be the cost-efficient way to solve their problem? As a matter of fact, you just need cost very little money for an AVCHD video converter, no more than $30, and it will totally resolve your problem.
In the following paragraphs, I would like to show you my own solution of converting AVCHD files to Adobe Premiere workable format via this kind of converter named Pavtube MTS/M2TS Converter, which is only $29, and without audio and video out of sync issues.
Step 1: Run this AVCHD video converter, and load MTS/M2TS files to it
Click "Add" button to import .mts and .m2ts files as long as you launched this program.
Step 2: Select output format and set save path
Click on the drop-down list of "Format" to select an output format for importing to Adobe Premiere. This utility has specific format profile for Adobe Premiere, and you just need choose one according to your own needs.
Click the folder icon at the opposite side of "Output" to specify the save path of the output files. At the same time, if you want to combine multiple files into a single file, you can tick the checkbox "Merge into one file".
Step 3: Click "Settings" button to do advanced settings
All the parameters in the popup window are changeable, including codec name, aspect ratio, bit rate, frame rate, sample rate, and audio channels.
Step 4: Click "Convert" button to start conversion
Once finished, the output files can be found out via clicking on "Open" button.
on Jan 30, 2010 | Cameras
Tip
Convert Stubborn Webpage to pdf...
I have come across some websites that I wanted to save the page for later review. I found that I was having some problems with certain sites. I found a ways around it.
What you need:adobe acrobat pro (latest version) or better popupcop.
There may be a simpler way to do this but if found that this works:
When at a webpage that you want to copy (YOU MUST BE USING IE AND HAVE BOTH POPUPCOP INSTALLED AND ADOBE ACROBAT PRO OR HIGHER, CONVERT TO .PFG), slide popupcop popup intensify bar to the far left, now click on adobe acrobat icon to convert webpage to .pdf document. I have yet to find a webpage where this trick does not work.
I't might help you a lot. Good luck!
on Jan 18, 2010 | Computers & Internet
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
Need to dowload adobe free copy 6.0 or higher
Here is the dowload site for the free Adobe Reader 9.3;
http://get.adobe.com/reader/
Here is the download site for a 30 day free trial of Adobe Acrobat Professional 9 Pro;
http://www.adobe.com/products/acrobatpro/tryout.html?sdid=FBYHW
May 10, 2010 | Adobe Acrobat 9 Standard Full Version for...
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
Troble saving pdf after trying to make changes
I would think either you need more hard drive space or more system RAM... thats a BIG meatball!!
Jan 29, 2010 | Adobe Acrobat 9 Standard Full Version for...
Computers & Internet Logo
David Payne
David Payne
