Copying i have one image of god in my pictures with jpg format, please inform how to copy it and paste on other page,
  • srinivas59 Sep 30, 2008
    i tried the procedure what you said but i am not successful. i think it does not work in case of pctures,.because,in first stage i am getting copy by using right click on mouse.but while i am trying to paste it , i am not getting paste on menu, iam getting only delete.
  • srinivas59 Oct 01, 2008
    i tried this time also.the copied item is appearing in clipbrd.exe.but same thing occurs while pasting, after right click of mouse, only "delete "'highlights.cut,copy, paste are appearing but not working . i think i am failing somewhere.you explained very patiently. thank you very much.i am working in bank.i am able to understand whatever you explained,
    rvrao
  • 781 Answers
1.use your mouse
a. go to the folder where the image is.
b. right click on the image
c. select copy
then...
d. go to the other folder or other location where you want to have the image pasted
c. make sure the new location folder is active (check the the top of the window is not dimmed.. if it's not proceed, it it's dimmed click on it.)
e. with your mouse put the pointer on a blank space on the area where you're pasting the image and right click
f. select paste.. your image should appear
or
2. Use your keyboard
the other way is to select the image and press the "ctrl" key and the "c" key simultaneously
then go to the location where you want to have image pasted and press the "ctlr" key and the "v" key simultaneously
either method should work.
Posted on Sep 29, 2008
  • 2 more comments
  • Francisco Cortes
    Francisco Cortes Sep 30, 2008
    based on your rating my solution did not work. could you elaborate on what you're trying to do to possibly assist you further?
  • Francisco Cortes
    if you don't get the paste option is simply because you have not copy the item as instructed, the paste option will be selectable only if you have copy something.
    no matter what type of file you're working with, image, video, text...etc.. copy and paste procedures are the same. does it work with other files?
    try method 2 only selecting the image you want to copy (selecting means to highlight the image by clicking once on the image) and then press ctlr and c at the same time ... then go the the destination folder and press ctlr and v at the same time (make sure not to press esc other wise the copied image won't be avaliable to be copied anymore). if done correctly a copy of the image file should appear in the destination folder
  • Francisco Cortes
    Francisco Cortes Oct 01, 2008
    ok.. let's get serious...
    1. check your clipboard holds the image you want to copy.
    everytime that you use right-click and do "copy" or when you select something and press cltr+c, that item should go into something called the clipboard... your clipboard should be located in c:\WINDOWS\system32 folder, the program is called clipbrd.exe.. if you want to see if the copy function is working do select an item and do right-click>copy or select and item and do a cltr+c then check if a path to the item selected to be copied shows up in a page on the clipboard which you can open to see for yourself on start>run> tipe clipbrd.exe and the clipboard viwer will open up... expand the page that maybe minimized for you to see the content of your clipboard (with an path to the location of the item you have selected and wanted to copy. if you don't see it you may have a corrupted clipbrd.exe file.. try replacing the file from another windows installation same as yours.
    2. try pasting the image in blank area in your new folder:
    a. first make sure you change the view of your folder. (that may make things easier.. it's not critical though).. on the menu bar go to view>and select any of the following "list" or "icons" or "details", your choice.
    b. try to paste the previously copied item by right-clicking on an EMPTY OR BLANK area in your destination folder. you should see a context menu with the paste oPtion enabled (present for you to select it) or simply press ctrl+v (that is press the ctlr key and without depressing the cltr key also press the "v" key then release. you should see your copied item being pasted into your new folder.
    I'm not sure what your experience with computers is, and please don't take me wrong but if this instructions are hard for you to follow you may want to ask for someone that can read the instructions, follow them and show you how you can do it...
  • Francisco Cortes
    Francisco Cortes Oct 04, 2008
    how is your computer in terms of virus/malware.. scan your computers with updated antivirus... I've doing some research and I'm running emtpy..
    what about using the ctrl-c (copy) cltr-v (paste).. you never said anything about using those keyboard shortcuts...??
    does it work with any other image, file or document?
    do you have permissions to write/change on the folder where your trying to copy the image to? try another folder and see if you can copy the image.
    is this your computer or your companies computer?? send the image as an attachement to yourself and when your get your email try to download the image onto the other location.
How to attach photos to an email
Click on the paper clip icon an it will direct you to your pics
Aug 29, 2017 | Computers & Internet
I can not copy and paste to Facebook
How to Copy and Paste on Facebook
Method 1 of 3: Copy/Paste To Facebook
  1. jpg" alt="Copy and Paste on Facebook Step 1.jpg">
Method 1 of 3
step 1
Find the text or link address that you want to paste into Facebook. Highlight that information by clicking and dragging over it with the cursor on your mouse.
jpg" alt="Copy and Paste on Facebook Step 2.jpg">
step 2
Right click with your mouse. Select "Copy" from the drop down menu.
  • Press the Control key and the letter "c" simultaneously to copy information quickly on a Windows computer.
  • Press the Command key and the letter "c" simultaneously to copy information using the keyboard on a Mac computer.
jpg" alt="Copy and Paste on Facebook Step 3.jpg">
Log in to your Facebook page on your Internet browser. Go to your Profile.
jpg" alt="Copy and Paste on Facebook Step 4.jpg">
Click on the text that reads, "What's on your mind?"
jpg" alt="Copy and Paste on Facebook Step 5.jpg">
5
Right click your mouse and select "Paste" from the drop down menu. Your text or link should appear in the box. However, formatting, like bold, italics and underline, will not transfer.
  • Press the Control key and the letter "v" to paste quickly on a Windows computer.
  • Press the Command key and the letter "v" to paste quickly on a Mac.[1]
jpg" alt="Copy and Paste on Facebook Step 6.jpg">
6
Change the spacing of the text using the Enter and Delete keys. If you pasted a link, a small image and description should pop up below your status bar. You can highlight and delete the link text and replace it with your own personal description of the information.
jpg" alt="Copy and Paste on Facebook Step 7.jpg">
7
Press the blue "Post" button to publish your copy and pasted information.
Method 2 of 3: Copy/Paste From Facebook
jpg" alt="Copy and Paste on Facebook Step 8.jpg">
Log into Facebook on your personal computer. These instructions do not work for cutting and pasting on smartphone or tablet applications.
jpg" alt="Copy and Paste on Facebook Step 9.jpg">
Scroll through your News Feed or your timeline to find the information you would like to copy and paste.
.jpg" alt="Copy and Paste on Facebook Step 10.jpg">
Click on a link in a post if that is the information you want to copy. When a new tab opens with the full article displayed, you should highlight the address bar so that you can paste it elsewhere.
.jpg" alt="Copy and Paste on Facebook Step 11.jpg">
Click and drag your mouse across the text on the screen. Highlight everything that you want to copy.
5
Press the right mouse button. Scroll down and select "Copy" in the drop down menu.
  • Use the copy shortcut if you prefer. It is Control and "c" (Windows) or Command and "c" (Mac).
  • Use the same method with the full link URL if you clicked on it previously.
6
Open a document in a program like Word, Text Edit, Notepad or Excel.
7
Right click and select "Paste" from the drop down list. Your information should populate next to your cursor. You can format it or change it according to your needs.
  • Use the paste shortcut if you prefer. It is Control and "v" on Windows and Command and "v" on a Mac.
Method 3 of 3: Copy/Paste in Third-Party Apps
.jpg" alt="Copy and Paste on Facebook Step 15.jpg">
Download the a Facebook app. It will allow you to access Facebook from your device.
Find information on a website, message or email that you want to copy. Tap and press. Choose "Select All."
Tap and hold again. Choose the "Copy" option this time.
Navigate to your Facebook app. Find the Status Update bar or a Comments section of another post.
5
Tap and hold your finger down. Select "Paste" when it pops up. Change your text or link as necessary. Then, tap "Post" to publish it.
Tips
  • Instead of copying and pasting the information from another post into Facebook, click the "Share" button in the bottom right corner of the link, text or picture. Facebook will ask you if you want to share it on your timeline. Confirm and it will paste the post onto your page.
Aug 24, 2014 | Computers & Internet
I downloaded some picture files to my daughters mac laptop and want to transfer them to my desktop pc
Most picture formats, the part of the file after the dot, are the same for both types of computers, ie jpg, gif, tif, etc. So if you have the computers networked it's just a matter of copying them over the net from one machine to the other.
If you don't have them networked you can use a 'jump drive', which is a storeage device that plugs into a USB port and copy them to the drive and then stick the drive in the other machine and copy them off. Jump drives, sometimes called Thumb Drives or USB "sticks" have really come down in price these days.
Otherwise your third choice is to burn them to a dvd and then copy them to the other machine via the dvd you made. Or if you really want to do it the long way you could email it from one machine to the other :)
Jul 28, 2011 | Computers & Internet
Today when i connected my camera to my computer i thought of copying pictures from my pc to my camera. I opened 'My Computer' and opened the folder of my camera. There I pasted one of my photos....
If all the pictures you copied were originally taken with this camera, then it is certainly because you modified this particular image - renamed it or a rotation from portrait to landscape.....
If this is not a picture taken by this camera, then this is normal, camera are usualy able to see only picture it has taken.
Hope this helps
May 18, 2011 | Cameras
How do you download photos on a site so they cant be copied
hello there 1. open the web page that you want to save images 2. theres a button on the keyboard called print screen 3. press the print screen button then go to paint then paste it (ctrl+v) 4. save the image in jpg format 5. then crop the image that you want by using any photo editing software
Dec 19, 2010 | Computers & Internet
How to copy picture from a video DVD to picture file
Pause the video on a frame/image you want to copy. Press PRINTSCREEN on your keyboard. Open an image editor (eg. Paint, photoshop or any other) and paste the screen. Then crop just the image from the video player and save it as JPG image. Thats the way
Jun 27, 2010 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
I want to change the signature on my outgoing emails. How do I do that? Can I add a logo to it?
1. Go to your email box.
2. Click on 'Options' (upper right, blue letters).
3. Scroll down to and click on 'Signature' (second column, under 'Management').
4. Select> 'Editor: Plain | Color and Graphics.
5. Enter signature text and/or graphics (you can 'Copy' and 'Paste' text and/or graphics directly into the input field).
8. Check the box:
'[/] Add signature to all outgoing messages'
Or leave the '[_] Add signature....' box unchecked and check box below compose area (when sending messages) '[/] Use my signature'
9. Click on the 'Save' button (upper left, under 'Mail' tab).
You can 'Copy' and 'Paste' your pictures directly into the input field (if the image is JPEG format - ".gif" or ".jpg"), but there is limited space. If your picture suddenly disappears, it may have gotten corrupted during the process, try it again. Note: some images may not allow you to copy them due to HTML restrictions on the page.
If your picture is in your computer, you can send it to yourself via an attachment and it will be in your 'Search Shrtcuts' > 'My Attachments' - 'My Photos' folders.
After you locate your picture in the search shortcuts folder:
1. Double-Left click on the photo to open.
2. One-Right click on open photo to reveal the pop-up menu.
3. Choose 'Copy'.
4. Go to signature input box and one-Left click on target area to set cursor.
5. One-Right click to reveal pop-up menu.
6. Choose 'Paste'.
Or you can upload your image to 'Photobucket.com' and 'Copy' it from there.
Photobucket
http://photobucket.com/
The Color and Graphics version of Yahoo! Mail also gives you the ability to include HTML graphics in your signature, by doing the following:
1. Locate an image (".gif" or ".jpg") that you wish to add to your message. This image can be selected from the Web.
2. Once you find your your picture of choice, right-click your mouse and select "Copy" from the menu that appears next to your cursor. Note: some images may not allow you to copy them due to HTML restrictions on the page.
3. Login to your Yahoo! Mail account.
4. Click the "Mail Options" link in the upper right-hand area of the page.
5. Click the "signature" link in the left-hand Personaliztion column.
6. Make sure the cursor is in the Color and Graphics signature field and paste your copied image by pressing "Ctrl+V". Your fonts, sizes and colors should all remain the same. You can also resize your image.
If you would like to edit your signature in the future, just return to the Signature area, make the changes you want, and click "Save."
Jan 18, 2010 | Yahoo Mail
I try to copy an image on my new yahoo mail but
Good day sir/maam, hi, if you would like to copy an image from an email, paste it first on MSPaint, and save it as .jpg, then use the file attachment to send it to another email. ( to explain it, its like you have copied only the "soul" of an image but not the physical file, so you may need it to paste it first on MSpaint to give it a "body" to be consider a picture. ) hope this helps.
Oct 08, 2009 | Yahoo Mail
Copy photos from computer to camera
Although you can copy images from your computer to your camera, the camera will be unable to display them, so it is a pointless exercise.
Dec 03, 2017 | Canon PowerShot S51S Digital Camera
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
