Question about Troy Bilt Tb70ss Gas Trimmer
Starter cord has detached internally and I cannot get to it
I have taken every screw out but cannot rmove the plastic cover to get the starter cord and its connection. The cover is loose but the metal part which rotates and links to the cable in the shaft is stopping me. I have tried some force whithout success and suspect I need a special tool to go inside and unscrew this part. It has a small internal diameter and no screwdriver I have will fit (and I cannot see what is at the bottom anyway)??
  • 3 more comments
  • Anonymous Sep 28, 2008
    not detatched but will not rewind - can't seem to find my way inn
  • Anonymous Oct 19, 2008
    I have the same problem bad starter assembly but can't get to it to fix it.
  • tgtree Dec 18, 2008
    with only about a dozen uses, the TB70SS is now completely useless. The starter rope - the pull rope that actuates the starter, has broken. As with other users, I could not discover a simple way to access the pull rope, and the schematics are a little scary. Anybody know how to do this? Or should I take it to a pro.
  • Anonymous Apr 22, 2009
    I have the same, I can't get in to rewind the starter rope. Is there a schematic I can view?
  • kjestimate May 11, 2010
    The TB70SS has a #20 torx screw that holds it on. Once the clutch cover is off, however, the clutch assembly is still in the way. Do I need a puller to get the clutch off of the shaft?
    Champion:
  • 225 Answers
Depending what make and how old the machine is,usually there is a torx screw in the middle of the clutch drum(metal part that rotates).you will need to use a piston stop,to stop the engine turning while trying to undo the torx screw. i am assumig the starter is in front of the engine not at the back. once the screw is undone the clutch will come off and so will the starter cover. neil
Posted on Dec 19, 2008
Starter handle will not catch
It's possible that a few things are happening. Some recoil set us have the dog ears, the little plastic piece that flaps out and catches the flywheel bell. Have you taken that cover off the unit yet? If not, take it off, pull the cord and see if either the dog ear is broke or something else is...this is an easy fix, recoil assys are not expensive at all... it all starts with that pull cord assy. Should be 4 screws that hold on the side panel to the saw, just don't take the recoil pulley out or you may find the spring will pop free from where it sits..
Oct 05, 2015 | Garden
How to change cord victa corvette 160cc 2stroke electronic ignition
On assuming its fitted with a victa 2 stroke engine in which case unscrew the 3 cross head screws on the top plastic cover and remove it. You should then see the top of the engine and the recoil starter. Undo and remove the 3 bolts holding the starter to the engine. Remove the starter housing gently as there will be a large o ring under the stater. Once the starter is off you can undo the centre bolt and remove the recoil pulley and spring. When refitting starter smear a little oil on the large o ring to stop it from being damaged
Oct 11, 2014 | Garden
How to change the solenoid on 2008 haritage softail classic ?
If you are not mechanically adapt do not try this as it involves quite a lot of disassembly.
First, disconnect battery, negative side first.
1. Remove primary chaincase cover.
Bend tab on lockplate away from
head of jackshaft bolt. Hold pinion gear in place and
remove jackshaft bolt, lockplate and thrust washer.
4. Remove rear exhaust pipe.
5. Remove screw and end cover from starter.
6. Remove oil tank to provide clearance for starter removal.
7. Remove both starter mounting bolts and washers. This includes detaching the engine ground cable.
8. Remove protective boot over connector. Remove nut with washer (metric).
a. Remove positive battery cable ring terminal.
b. Remove circuit breaker wire ring terminal.
c. Detach solenoid wire.
9. Remove starter from right side of motorcycle.
Assembly is in reverse order. As you can see, quite a big job.
Jun 21, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
What's the plastic shield blocking the Starter? How to get past it to replace starter?
It`s a heat shield,there should be plastic caps covering the screws to remove that to reach the starter.
Oct 12, 2012 | 1998 Oldsmobile 88
How to put a new pull rope on it How do I put a new pull rope on
It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
Aug 18, 2011 | Husqvarna Chain Saw 20" Bar
How do I replace the pull start?
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
The saw was working fine. I shut it off. When I attempted to pull the cord to start it again, the cord would not retract. I removed the cover, disassembled everything related to the cord. Made sure the...
Many of these small saws have what is reffered to as an e start, the section that engages to the flywhell is seperate to the rope pulley, and is joined via a round coil spring, the idea is to soften out the compression and help to spin the engine over when cranking, one end of the spring fits into the outer flyheel engagment pinion, the other ends fits into a hole in the starter cord pulley, it does not fit into the main recoil spring, the securing screw for the assembly is a shoulder screw the idea is not to pinch the rewind mechanism when tightened, as this only screws into plastic it is very easy to over tighted and make the pulley post swell and stop the pulley rotating on the shaft, you may now need to leave the screw just a little slacker, the black plate under the starter is a conductor plate, this helps blow the cold air from the flywheel over the cylinder, this plate should always be there. When assembling the starter on the saw, keep pulling the rope as the cover goes on, this will ensure the pinion engages properly with the flywheel pawls.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to get to starter on 2003 traikblazer
Removal & Installation 4.2L Engine To Remove:
  1. Disconnect the negative battery cable from the battery.
  2. Disconnect the brake booster hoses from the engine. Starter gm-02-42-1398.gif
  3. Remove the positive battery cable and s-terminal lead from the starter.
  4. Remove the starter from the engine.
To Install:
  1. Install the starter to the engine. Tighten the nut and bolt to 37 ft-lb (50 Nm).
  2. Install the positive battery cable and s-terminal to the starter. Tighten the battery cable nut to 80 in-lb (9 Nm). Tighten the s-terminal nut to 20 in-lb (2.3 Nm).
  3. Connect the vacuum brake booster hose to the engine.
  4. Connect the negative battery cable to the battery.
5.3L & 6.0L Engines To Remove:
  2. Raise and support the vehicle.
  3. Remove the rear steering gear crossmember from the frame. Starter gm-02-53-1399.gif
  4. Detach the wire harness from the transmission oil cooler line bracket.
  5. Detach the transmission oil cooler line bracket from the engine.
  6. Remove the right transmission cover bolt from the transmission cover.
  7. Detach the starter from the engine.
  8. Slide the starter forward and remove the transmission cover.
  9. Remove the heat shield from the starter.
  10. Position the starter so that it can pass between the engine oil pan and transmission oil cooler lines.
  11. Detach the starter lead and battery positive cable from the starter.
  12. Remove the starter from the vehicle.
To Install:
  1. Place the starter between the engine oil pan and transmission oil cooler lines.
  2. Attach the battery positive cable to the starter and starter lead. Torque the battery positive cable nut to 80 in-lb (9 Nm). Torque the starter lead nut to 30 in-lb (3.4 Nm).
  3. Install the heat shield to the starter.
  4. Attach the starter from the engine. Torque the bolts to 37 ft-lb (50 Nm).
  5. Install the right transmission cover bolt into the transmission cover. Torque the bolt to 80 in-lb (9 Nm).
  6. Attach the transmission oil cooler line bracket to the engine. Torque the bolt to 80 in-lb (9 Nm).
  7. Attach the wire harness to the transmission oil cooler line bracket.
  8. Install the rear steering gear crossmember onto the frame.
  9. Lower the vehicle.
  10. Connect the negative battery cable to the battery.
Aug 19, 2010 | 2003 Chevrolet TrailBlazer
05 gmc envoy xl v8 starter removal
YOU HAVE TO REMOVE REAR STEERING GEAR CROSS MEMBER.REMOVE THE WIRE HARNESS FROM THE WIRE HARNESS RETAINING CLIPS ON THE TRANSMISSION OIL COOLER LINE BRACKET.REMOVE TRANSMISSION OIL COOLER LINE BRACKET BOLT.REMOVE RIGHT TRANSMISSION COVER BOLT.THEN REMOVE STARTER BOLTS THEN REMOVE STARTER.
Apr 07, 2010 | 2005 GMC Envoy Xl
Starter replacement
This is straight out of the Harley service manual.
I think a lot of this makes sense once you start pulling things apart but some might cause you a little grief, My advice is get a service manual.
Good luck.
1)disconnect negative battery cable.
2)Remove primary cover, (that's the primary chain case cover).
3)Bend tab on lockplate away from head of jackshaft bolt. Hold pinion gear in place and remove jackshaft bolt lockplate and thrust washer.
4)Remove screw and end cover from starter.
5)Remove oil tank to provide clearance for the starter removal.
6)Remove both starter mounting bolts and washers. This includes detaching the engine ground cable
7)remove protective boot. Remove nut with washer.
a)remove positive battery cable ring terminal.
b)remove circuit breaker wire ring terminal.
c)detach solenoid wire.
8)Remove starter from right side of motor.
Sep 09, 2009 | 2004 Harley Davidson FXSTD - FXSTDI...
Troy Bilt Tb70ss Gas Trimmer Logo
490 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
