Amplifer can be operated using remote control or controls on amplifier. The only thing that isn't working is the text diplay. What can cause this problem?
SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
[email protected]
SOURCE: The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
SOURCE: Yamaha RX-V520
If you don't have any speaker wires hooked up to it and it won't turn on, the only thing left to check is the internal fuse. First, make sure it's unplugged from AC, then remove the top from the receiver, 6 or 7 small phillips head screws. At the back inside corner where the AC comes in there is either one or two fuses, check them. If you have a multimeter, dial it to resistance & sound (meaning when the two probes touch you will hear a tone) touch both ends of the fuse with the probes, if you get tone, fuse is good, if not, replace the fuse and all should be well. If you get tone, you've got either bad transistors or a bad power supply. Could be a 100-200 repair. Hope this helps
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
