Question about Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 424-700G Burner/Pressure Issue
I have a coleman dual fuel 424-700G stove and a lantern that both have the same issue. I mistakenly left fuel in the tanks over a winter and neither now works. I replaced the generators on both and they still don’t work.
It feels like the pumping mechanism is not working correctly. If I try to pump the pump with my finger over the air hole it is difficult to pump and does not feel like it is building up pressure in the tank. I cannot pump up the pressure and close and turn the pump handle to seal it without letting my finger off of the air hole to let air escape. Neither unit pumps like they did when they worked correctly where you could pump smoothly and feel the pressure building up and then easily turn and lock the pump handle.
If anyone can provide any guidance on what the issue might be and what I can try to do to get them back up and running correctly.
I had a similar problem today, After taking the ump assembly to pieces i disovered that the pump"stem" needed turning slighty anti clckwise to allo tepresure to build up inthe tank. I felt very stupid buta big learning curve for me.
Posted on Jun 07, 2009
413h coleman
Do you mean unleaded? Officially no, unless it's marked "unleaded" or "dual fuel" (in Coleman speak, dual fuel means unleaded gasoline OR white gas) which means all the seals are rated for the additives in road fuel.
Unofficially yes, but gasoline is not a good idea because it tends to clog the generator with soot, it goes stale very quickly and it smells bad.
I would stick to Coleman fuel, Primus Powerfuel or Aspen 4. You probably don't get through so much of the stuff that cost is a big issue.
Aug 03, 2013 | Coleman 2 Burner Dual Fuel 424-700G Grill
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
My coleman dual fuel lantern wont let me pressure the fuel up with the plunger
Remove the plunger and oil the leather diaphram with light oil similar to 3 in 1 oil, and expand the diaphram until it is no longer stiff and contracted. If you do not know how to remove the plunger let me know.
Sep 16, 2010 | Coleman Cable Coleman Twomantle Dual Fuel...
VALVE WHEEL LEAKS
Here is Coleman's repar part website.
You may want to replace the valve if it is leaking.
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=210
Jul 21, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman dual fuel - troubleshooting steps
Got my solution by talking to a fellow at REI. He showed me how to take the Coleman apart and check for problems.
Jan 04, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
722 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
