Question about Logitech QuickCam Chat Personal Web Camera
Quickcam v11.1 for skype
I have installed the cd software and can access a veritcal toolbar that has a camera and video and other options, but do not know how to make myself appear to my chat friend on skype. Is there a function that needs to be selected on skype?? Thanks!!
Solution was I needed to download the latest edition of Skype!
Posted on Sep 29, 2008
How to use skype 6.0 with logitech c-310
Launch the Logitech QuickCam or Webcam software on your computer. Verify that you see yourself Logitech Webcam software window. Close the software window. Sign in to Skype. Click the "Tools" menu and select "Options." Click "Video Settings," check the "Enable Skype Video" and "Start my video automatically when I am in a call" boxes. Select your Logitech QuickCam from the drop-down list. Your webcam should display video in the window. Click "Audio Settings" if your QuickCam has a built-in microphone and select it from the microphone drop-down list. Check the "Let Skype adjust my audio settings" box in "Audio Settings" so Skype recognizes your microphone. Click "Save" to save the options for your audio and video settings. Skype will close the options menu.
Jan 19, 2013 | Logitech C310 Web Cam, Skype, Computer...
Hi, i tried using skype with logitech quickcam but pup-up told me this message: Another application (communications helper.exe) tries to access Skype but we are not able to respond. Try to restart the...
The easiest thing to try is just disabling "Communication_Helper.exe" in Skype. Go to Skype / Tools / Options / Advanced, and at the bottom you will see text that says "manage other programs' access to Skype". Click that and you'll get a window, which should list "Communication_Helper.exe". Deny access to that (don't remove it, because it will just come back), and try your call again.
Be aware, however, that this is only a quick fix and does not solve the problem. When Logitech and Skype have problems like this, they can be pretty big ones, and can cause performance problems as well as interface problems.
The Logitech QuickCam application software is not required for the Logitech Camera to function properly in Skype. If you are not using the QuickCam application for anything else, then you should seriously consider uninstalling it.
That will solve this problem, and various other potential problems and performance issues, permanently.
To uninstall it just go to Control Panel / Add or Remove Software (or Uninstall a Program in Vista/7), find "Logitech QuickCam" (NOT Logitech Camera drivers), and uninstall.
Then reboot to get rid of the background processes, and test Skype again.
May 05, 2011 | Logitech QuickCam Connect Webcam
How can i install my logitech qickcam camera for windows vista
Normal 0 Double click on this site
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image (Match what yours looks like)
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System
. Then you will get your download driver.
Then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with. Just installing the cameraon your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Yourfriends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
May 31, 2009 | Logitech QuickCam Express Web Camera
Mirror effect
Normal 0 Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work. Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
Mar 17, 2009 | Logitech QuickCam Pro 4000 Webcam
I am unable to install my Logitech Quickcam Express Web Camera. I get the following error ''The class installer has denied the request to install or upgrade this device''
A. Skype Setup:
B. Yahoo Setup:
Mar 15, 2009 | Logitech QuickCam Express Web Camera
Logitech quickcam skype
Reinstall the software and watch for the langue selection and select English.
Also download the latest drivers here.
Normal 0 To get the latest Microsoft Web Camera drivers, double click on this site
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
then select the necessary items as listed below, such as
  1. Select type of product. (Web cam)
  2. Select your product (camera model).
  3. Select your operating system. (XP, Vista etc.)
  4. Select your operating system langusge. (United States English)
Then do this:
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/bd ) set it up as follows:
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://messenger.yahoo.com/download/bd ) set it up as follows:
Hopethis helps. Bud
Mar 15, 2009 | Logitech Quickcam Chat Webcam
Quickcam will not start in Windows Vista
Running Windows Vista Ultimate, using QuickCam Orbit AFT, installed QuickCam v11.8, same problem, error window states "Quickcam.exe has stopped working" - I've uninstalled, reinstalled, uninstalled, reinstalled download from logitech, uninstalled, etc., etc., no same message. Seems like a lot have similar problem, must be an answer out there.
Feb 11, 2009 | Logitech QuickCam Communicate Personal Web...
Hi, i would like to take live picturs and/or video while i am chating with skype and dont know how to do it. will you help me ? thanks, eddie
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Skype issues with your QuickCam Communicate STX trnsp.gif Detailed Description 1754.1.0.jpg This article explains what to do if you have problems using Skype with your QuickCam Communicate STX.
Model Number: V-UBK45
trnsp.gif Answer If you are experiencing difficulties using the QuickCam Communicate STX with Skype, check the following:
Verify the QuickCam Communicate STX is functional:
  1. Launch QuickCam software (Start > Programs > Logitech > Logitech QuickCam)
  2. Verify that you can see yourself in the QuickCam window as shown below:
  3. Close the QuickCam window.
Verify that the QuickCam Communicate STX is selected in the Skype Settings:
  1. Launch Skype (Start > Programs > Skype > Skype)
  2. Click Options from the Tools menu as shown below:
  3. Select the Video Settings option from the Skype sidebar as shown below:
  4. Check the Enable Skype Video checkbox as shown below:
  5. Check the "Start my video automatically when I am in a call" checkbox as shown below:
  6. Verify that your QuickCam Communicate STX is selected from the Camera drop-down menu as shown below:
  7. Verify that your QuickCam Communicate STX is selected from the Microphone drop-down menu as shown below:
  8. Verify that the "Let Skype adjust my audio settings" option is checked in Audio Settings as shown below:
If you still cannot see or hear the other person, it can be due to a variety of possible issues, including:
  • Windows or third-party firewalls
  • Your internet service provider (AT&T, Comcast, etc) could be blocking certain services.
  • Missing Windows system components.
Jan 10, 2009 | Logitech Quickcam Chat Webcam
No video in Skype 3.8 with Logitech QuickCam Pro 9000
Sounds like your classic driver problem. Look in Device Manager and find your webcam. Right click on it an update driver/reinstall driver.
Dec 31, 2008 | Logitech Quickcam Chat Webcam
Webcam - Recipients can't see me.
I got this of Skype.
We are sorry to hear that you are having problems with Skype video.
Thank you for contacting Skype customer support about your video settings.
If you are using a Logitech webcam, please follow the steps below:
NB! To begin with please close Skype and make sure that you have unplugged the webcamera before installing the installation software that came with it.
1) Go to the control panel and open Add/Remove programs. Then from there uninstall any Logitech webcam software and Logitech webcam drivers from the list shown.
2) Download the latest drivers for your webcam from
http://www.logitech.com/index.cfm/405/&cl=roeu,en?prodcrid=405
3) Open the webcam installer package by double clicking it.
Now select: Custom installation (advanced) and click next. You are now given a choice whether you would like to install the software and drivers or just the drivers. Please select the second option (Logitech QuickCam drivers) then uncheck 'Enable VoIP Device Management' and click 'Next'. Accept the agreements and on the next page select 'I do not want to activate this Service' (Logitech destkop Messenger). Click 'Next' and the Logitech drivers should be installed. Restart your system and plug in your webcam. Your webcam should now be correctly installed.
Oct 31, 2008 | Logitech Quickcam Chat Webcam
Logitech QuickCam Chat Personal Web Camera Logo
254 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
