Question about HP PSC 1510 All-In-One InkJet Printer
HP PSC 1507 paper jam after changing cartridges
Picks up the paper, goes half way thru then stops until resume pressed
  • Anonymous Mar 12, 2009
    idem
  • puttn4eagle May 09, 2009
    Can anyone help? I'm unable to print any docs as the paper just feeds halfway. Turning it off/on just spits the paper out. The last posted solution was useless.
I have to intall my HP PSC 1510 All-in-One Printerand i lost the cd for do that what can i do ?
Posted on Oct 15, 2008
Light flashes next to "check printer cartridge"
For an illustrated version of the text below go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00095617&cc=us&lc=en&dlc=en&product=306895&tmp_track_link=ot_search
Check Paper Light Blinking
Figure 1: Check Paper light blinking At the start or in the middle of a print job, the Check Paper light begins to blink. The unit will not print. If the unit is connected to a computer and the HP software has been installed, one of the following messages is displayed:
  • There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume, or Okay button on the hp psc.
  • The unit is out of paper. Load more paper and press the Enter, Resume, or OK button on the hp psc.
If both the Check Paper and the Check Print Cartridge lights are blinking simultaneously, or if the computer message is The print cartridge carriage is stalled , click here for troubleshooting information . Step 1: If the unit is out of paper, load more paper
  1. Move the paper guide out, load the paper, then adjust the paper guide. Make sure the paper is flat in the tray. Figure 2: Load paper
  2. Press the On/Resume button. Figure 3: On/Resume button
If the unit is loaded with paper and the light is still blinking, go on to the next step. Step 2: Remove jammed paper from the rear of the unit
  1. Unplug the product.
  2. Press the tab on the left side of the rear access door and remove it. Figure 4: Unlatching the rear access door by pressing the tab on the left
  3. Remove all the jammed paper and foreign material. Pull the paper slowly and gently to avoid tearing it or damaging the print mechanism. Avoid touching the internal components.
  4. Replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area. Then snap the door shut. Figure 5: Door pins in product holes
Step 3: Check the front of the unit for jammed paper
  1. Open the cartridge access door in the front of the unit. Figure 6: Open the cartridge access door
  2. Pull out any jammed paper or other foreign material you were not able to remove from the rear. Pull the paper slowly and carefully to avoid tearing it or damaging the print mechanism.
  3. Close the cartridge access door and plug the product back in.
How to avoid paper jams
  • Only insert paper into the paper tray until it meets resistance - do not push it farther in.
  • Make sure the paper is flat in the paper tray and the guide is adjusted to the width of the paper.
  • Do not add paper while the unit is printing.
  • Remove printed pages frequently.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Paper that has been printed previously may cause jams.
  • Make sure the rear access door is securely fastened.
  • If you follow all these guidelines and still have frequent paper jams, you may need to clean the paper rollers.
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Please vote if this is helpful. :)
Dec 11, 2010 | HP PSC 1350v All-In-One InkJet Printer
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP 1350 Says theres a paper jam and won't clear. All lights on.
Try unplugging the printer from power, (Turned off of course) Wait 5 minutes, plug the printer back in. Now open the case like you're going to clear a paper jam, or change ink cartridges. Close the case. Press the Power On button of the printer.
Jun 05, 2009 | HP PSC 1350 All-In-One Thermal Printer
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
May 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper jam notification after printing one page, no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp d1320
go over these steps
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Sep 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP2355 PSC
printer will not copy or print but takes in paper - it shoots it straight out but stops half way - we then have to press OK for the paper to be ejected.
The size of the paper makes no difference and it continues to take in pages even after the print has been cancelled - help
Feb 03, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP 3300
This procedure is described relating to a different error, but it resets and clears everything and would be worth a try http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl10206 hp says for your specific error: "Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge." here is the complete guide to all the above http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl11283 ask again if you need more Hope this helps :)
Mar 08, 2007 | HP LaserJet 3300mfp All-In-One Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
317 people viewed this question
Ben Johnson
