Question about Olympus Cameras
How to lock and unlock pictures on olympus fe-280
  • edosvk Nov 15, 2008
    i understand everything but how to turn the protection on & off? The manual doesn't say how to get to protection on/off mode. After i select the picture i want to adjust the protection for i dont know how to get to changing protection feature. I tried to access menu but i didnt see any way to change the protection there.
  • Tina Sourdif Dec 22, 2008
    I need to erase a video that I have locked without knowing
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
olympus fe-280
See page 25
This feature is called "protect" on the Olympus.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 28, 2008
  • 504 Answers
SOURCE: How to recharge battery of Olympus FE-280 Digital Camera
When you purchased the camera, there should have been a charge in the box (you got a lithium-ion rechargable battery with the camera, no?). You put the battery in the charger and plug the charger in the wall.
Posted on Mar 12, 2008
  • 479 Answers
SOURCE: blurry pictures
Try going thru the menu and reset camera. If not then repair
Posted on Aug 20, 2008
  • 11967 Answers
SOURCE: need to take apart an olympus fe 280 will not
Google the words...disassemble a digital camera.
Posted on Dec 08, 2009
leorcid
  • 281 Answers
SOURCE: my laptop doesnt recognize fe-280 olymous
Unisntall the software that came with the camera and reinstall them. If the computer asks for drivers, insert the cd that came along the camera and install the drivers. Alternately, you can use your laptop's card reader port to transfer pictures. Just take out the memory card from the cam and put it in the card reader slot. Have any questions, write back.
Posted on Dec 21, 2009
  • 11967 Answers
SOURCE: Olympus FE-280 8 megapixel Lens won't open.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 18, 2010
Need date and time stamp on my pictures with a olympus FE-280 camera
I attached 2 images:
If you don't understand, ask me for a link to this images and I will put it here.
May 11, 2011 | Olympus FE-280 Digital Camera
My laptop doesnt recognize fe-280 olymous
Dec 21, 2009 | Olympus FE-280 Digital Camera
Need to take apart an olympus fe 280 will not
Dec 08, 2009 | Olympus FE-280 Digital Camera
I've a Olympus FE 280 digital camera, please tell me the best ISO setting to click awesome pictures.
The ISO setting will vary with the lighting conditions. Your best option is "auto ISO".
Sep 17, 2009 | Olympus FE-280 Digital Camera
Dull colorless pictures
Have you made any changes to the settings? Check the ISO, picture quality (should be at highest setting), white balance, etc. You could also go into the setup menu and find the "reset" entry to reset back to default factory settings.
Aug 27, 2009 | Olympus FE-280 Digital Camera
Need pictures off Camera memory
memory card reader is the easiest way
Jan 02, 2009 | Olympus FE-280 Digital Camera
Blurry pictures
Aug 19, 2008 | Olympus FE-280 Digital Camera
FE 280 unclear pictures
Hello mcginnty and zeekachu.
Here's your link. Olympusamerica.com or
Consumer Division Tech Dept. 800-622-6372
8 AM through 10 PM EST Monday through Friday.
Outstanding customer support. ( rare in this day and age )
Also make sure you go to the FE-280 site at the above link and register your camera.
Olympus will extend your warranty by one month and give you a
discount on any accessories.
Regards, Paul
May 27, 2008 | Olympus FE-280 Digital Camera
Cameras Logo
301 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
