Question about Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
Certain shows or movies i try to record on At&t's U-VERSE , I get a pop-up saying " Cannot record in +VR mode " .
What can i do here ?
  • halliecochra Jan 11, 2009
    I am having the same problem... I checked and it is set at Standard Def... what can I do to get past this issue?
  • Anonymous Mar 21, 2014
    dvd-R with VR mode used will not record
Check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Posted on Sep 29, 2008
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Finalize dvd
hit stop go to setup menu pops up scroll down to finalize and hit enter
Jun 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Won't play on any other dvd
You have to use your friend's DVD recorder to finalize the disc. Once the DVD is finalized, it will play in other DVD players.
On your friend's DVD recorder, pop the disc in, and use his remote to go to Setup --> Disc Edit --> Finalize --> OK
Voila!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox MWR10D6 DVD Recorder
PAL/NTSC
It will not. The US models will only play Region 1 or Region ALL DVD's, and the UK is a different region entirely. There are illegal hacks to make it work, but since it is illegal, I will not post the directions here. Suffice it to say that there are videos on YouTube that show you the illegal method. Good luck!
-Tha Mp3 Doctor
Feb 02, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Hope this helps!
Jan 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How to set up my magnavox dvd player / recorder
http://safemanuals.com/user-guide-instructions-owner-manual/FUNAI/MWR10D6
Dec 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd recorder mwr10d6
The manual is located at: www.funai-corp.com/6pdf/om/MWR10D6.pdf (copy and paste in your address bar) hope this helps!
Jun 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
MAGNAVOX MWR10D6
You need to finalise the disc before it will play in a DVD player (DVD+-R), or make edits compatible (DVD+-RW)
Check out the "Playing the discs in other DVD players" section in the "Recording" chapter of the manual. (Page 36)
If you don't have the manual, it can be downloaded from this link
Mar 21, 2008 | Philips Magnavox MWR10D6 DVD Recorder
I cant record DVD's
If you mean burn a movie from the HDD to a DVD. It will only let you do this once.
Dec 30, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
1,458 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
