My Computer problems.
My computer's window is a xp, it had worked well when i bought it, but now, after I plug another hard drive, some folders icons were black and I also can not open them. They can not erased from my computer and for me it like a Virus, that if I deletes one of them, it could restores on it's own.
    Genius:
  • 1,250 Answers
Have you scan your system through a updated antivirus if not scan it
Posted on Oct 14, 2008
Installed new CD drive and computer wants to format hard drive
hey nothings wrong with both ur cd drives try doing this:
Click on the Start button.
If you're using Windows XP, also click on Run.
In the search box (Windows 7 and Windows Vista) or the Run textbox (Windows XP)
type regedit and click OK or press the ENTER key.
This will open the Registry Editor program.
Locate the HKEY_LOCAL_MACHINE folder under Computer/My Computer and
click the '> or (+) icon next to the folder name to expand the folder.
Continue to expand folders until you reach
the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Click on the '> or (+) icon next to the Class key to expand it.
You should see a long list of subkeys open up under Class that look something like this:
{4D36E965-E325-11CE-BFC1-08002BE10318}
On the rightside column.....delete upper filters and lower filters
restart the computer......that should fix the problem and you can use your old cd drive again......but if it doesnt......visit the nearest tech-centre
Mar 27, 2014 | Compaq Presario CQ60-220US PC Laptop
Can't find back-up folder
You might have to create a folder you can do this by right clicking in the backup destination drive selecting new folder and name it lets say Back Up 2012 for the excercise.
Determine how much space you need.
The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files.
You can do this in a couple of ways.
Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties."
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Your second option is to create a file called "Backup" and copy all of your important files into it.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
This is how much space you will need to back up your important files only.
Choose a backup method.
Choose either an external hard drive, data disks (CDs, for example) or use an online backup service.
Plug the flash drive or the External Hard drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
Hope this helps.
Nov 16, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
Feb 06, 2012 | Lenovo Computers & Internet
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
Am I able to password protect the 34974 Iomega external hard drive? I am not interested in encrypting, just having a password so it cannot be seen by others
Plug your Iomega hard drive into the USB port on your computer. Click the "Start" button and choose the "My Computer" icon. Double-click on your Iomega hard drive's icon. Right-click in a blank space on the window and choose the "New Folder" option from the menu that appears. Highlight and drag all of your data into the new folder that you created. Right-click the new folder and select the "Properties" tab. Navigate to the "Sharing" tab and check the small box next to "Make This Folder Private." Click the "Apply" button and then choose "OK." Use your Windows login password to access the folder and the contents. Hope this helps
May 20, 2011 | Iomega Select 2TB USB 20 Black External...
I have simply forgotten how to put stuff from my computer on to my external hard drive. I know it was pretty easy, but nothing cpomes up on my screen to go by. Thanks, Rochelle
The process is dependent upon whether you have an Apple Macintosh or Windows PC-branded computer. I will provide instructions for both.
Windows
Plug the hard drive into your computer. Then follow these steps.
1. Click the Windows logo button in the lower left corner of your screen to open the start menu. 2. If using Windows XP, click 'My Computer' on the right side of the menu that pops up. If using Windows Vista or Windows 7, click 'Computer'. 3. The window that opens will display all of the hard drives and other similar devices connected to your computer. Look for your external hard drive. Typically, the letter of the alphabet assigned to the drive will not be 'C:/' or 'D:/', but some other letter further down the line. 4. Double-click your external hard drive's name or icon. Another window will open. This is the contents of your external drive. 5. To copy files to the external hard drive, first locate the file you wish to copy wherever it might be on your computer. Then, click on the file you want to copy and while holding down the left mouse button, drag it into the window for your external hard drive. 6. The file is now copied. The same action can be taken if you also wish to copy whole folders.
Macintosh
Connect the hard drive to your computer, typically via a USB port.
1. The hard drive should show up as an orange icon on your desktop. Double-click this icon to access the contents of your hard drive. 2. To locate files, click on the smiling, rectangular face-shaped icon in the lower left corner. This is the Finder, and it allows you to find your files. 3. Once you've navigated to the file(s) you desire, (these are generally located in the folder along the left side of the window labeled with your name) click on the file names and drag them to the external hard drive icon, which is also located in the left sidebar of the finder window.
This will copy the files to the hard drive.
Hope this helps. If you would like more assistance, feel free to reply to this solution.
Thank you for using FixYa!
Mar 18, 2011 | Computers & Internet
After I plug in the hard drive there is no icon in the My Computer folder. I believe the computer is reading the hard drive as it asks if I want to remove it safely when prompted. I am on a PC with Windows...
http://www.ehow.com/how_6026_format-hard-drive.html
if you want to recover the data, http://www.google.com/search?hl=en&q=data+recovery+software&aq=f&aqi=g-e10&aql=&oq=
Feb 25, 2011 | SmartDisk FireLite 40 GB Hard Drive
HOW CAN I PUT A FOLDER AND THEN A FILE ON TO A SANDISK CRUZER USB 2.0 4GB FLASH DRIVE ?
When plugged on a computer running Windows, the SanDisk Cruzer appears as 2 icons: a CD-ROM and a regular hard drive. The drive letters for the two are consecutive (ex: E:CD_ROM, F:SanDisk.
Any file or folders that you have to store on the SanDisk drive must be stored on the second device.
If the folder already exists on your computer, point to it with mouse cursor and right click. In the menu options look for the one that says copy and select it.
Open the Windows Explorer, locate theCuruzer icon that represents the hard drive part, click on it to open it. Point somewhere where there are no icons and right click the mouse cursor. Select the submenu Paste.
To copy and paste you can also use the keyboard shortcuts CTRL-C and CTRL-V
You can also open 2 explorer windows side by side, one showing the folder you want to copy and another the contents of the SanDisk drive. You can drag the folder to copy from the computer hard-drive and drop
Aug 04, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I originally set up the drive with a windows XP 2000. When I plugged it in to my new windows 7, it wouldn't work. It shows the drive is maxed out, and I can't access it. I had used less than one half of...
How many files are on the drive? Are they in folders? The FAT formatting normally used for these drives limits the total number of files unless the files are in folders. I think the value is ~500 items - this is due to the minimum bytes to store each file. (If the files are in folders you can stack 500 items in 500 folders.)
One thing to try is to move the files to your computer, and then return them to the flash drive. (Formatting the drive after the files are safely on your computer is an option.)
Good luck.
Jun 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
