Question about ASUS NCT-D (90MSV430G0UAY) Motherboard
Whining noise from pc tower
The pc has got this annoying high pitched sound. I've checked the HDD by replacing it with another one. I've disconnected the floppy and DVD writers. The only thing I didn't check was the PSU and CPU. A pc technician advised me to remove the stickers from the fans and also the little cap and put a drop of oil on it. No result. The sound is still there. To me it sound like something on the M/B. Is it possible that a transistor on the M/B can make a high pitch sound? This M/B will be a year old in Oct.
  • bellabonzie
    bellabonzie Sep 30, 2008
    Thank you for your reply. I've replaced the psu, disconnected all my devices and only the motherboard was connected. The sound was still there. The cpu fan is clean from any dust as I clean my pc on a regular basis. I am a technician. This sound sounds like a capasitor or something vibrating just left from my CPU. It is not the CPU as I've disconnected it and the sound continiued. I even removed the ram one by one to no avail. The sound was still there. With only the M/B working and using 2 different psu units, it left me with the only the M/B. What really caught my attention was when I checked the bios setting and used the save and exit option, pressed enter, the sound stopped for a second. This is the only time I ever heard it stop. This sound starts very soon after start-up and the pitch stays the same allllllll the time. Sorry, I am so annoyed by this and doesn't enjoy my pc any more :-(.
  • pils Oct 12, 2008
    hello,
    i am facing a similar problem. only difference is tht the whining/rattling noise goes away after a couple of minutes . i suspected the psu initially. but after reading ur experience i don't know where else to look. have any suggestions. the noise is a recent phenomenon. all fans are clean. noise is definately not frm them.
I found the problem about this whining high pitched sound. It came from the "onboard" speaker. Disconnected it and the noise was gone. You disconnect the thin red and black wires coming from the LED connections. Good luck!
Posted on Oct 18, 2008
I have an asus nct-d with two nocoma cpus and the whining noise drove me nuts.
It was the fans on the cpus. The cpus run hot and the fans gotta haul *** to keep them cool
Hence the noise.
I water cooled the system and have had no noise or any other problems since.
I hope this helps.
    Scholar:
  • 191 Answers
No transistor will make such noise... The problem is not in your M/B. The problem might be due to the fan that cools your processor. So clean dust around the fan thoroughly.
Posted on Sep 28, 2008
4 Suggested Answers
SOURCE: cpu fan noisy/chip fan fail error messages
I had tons of problems with these Asus chip fans. I asked Asus to deliver 12 replacements (as I had a lot of pcs at that time with the same problem) It worked well, but placing a tiny heatsink well glued to the chip worked well also, as long as one does not want to overclock the thing. It's true that the temp raised a bit, but it remained pretty much in the tolerance area.
Posted on May 21, 2008
  • 34 Answers
SOURCE: BIOS WON'T START OR LOAD, ANYONE CAN HELP ME?
Found the following paragraph on manufacturer's web site.
asus.com
"The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support CD. Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM. "
Here's a link to Asus support site. It looks like the have a good tool for you to help troubleshoot your board.
support.asus..com
Hope this helps and GOOD LUCK!
Posted on Oct 16, 2009
SOURCE: A8n32-SLi Deluxe - Will not boot
your bios can be reset to defaults by removing the CMOS battery, then moving the little blue jumper to the right of it from the 1-2 pins to the 2-3 pins fpr 10 seconds, then place it back onto the 1-2 pins, replace the battery and boot as usual.
Posted on Dec 10, 2009
High pitched noise and Rattling in gear box.
sound like main shaft bearing assuming it is manual( if it comes on all the gears)
if it is automatic it must be your torque converter bearing
Apr 20, 2013 | 1992 Ford Ranger
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
Lg bd670 makes high pitch whining noise
It is the top of the dvd players "clutch" plastic wheel. There are gray rubber snubbers in a captured plastic wheel that disintegrates. Covered under warranty, but part number MKC 66030401 from electronics repair company such as Andrews Electronics at $19+sh. It is a very simple fix, remove cover,3 screws on back, lift off and 4 screws hold dvd on main frame. Carefully remove ears and lift off top of dvd, replace with new part. Good luck.
Dec 21, 2012 | LG BD670 Bluray 3D Player
03 nissan altima high pitch whine from engine
I assume that you have a 6cyl engine, noise came from both worned secondary timing chain tenssioner shoes, just replace those two and while you have them all apart, also replace main tenssioner and guide, then all noises will go away. Good luck!
Oct 13, 2012 | 2003 Nissan Altima
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Annoying high pitch noise coming from devise
I believe that this has involves the processor, and maybe the refresh rate (or the T E2's equivalent) being faster than the screen would like.
Sorry for the personification there (I want to sound smart.)
Nov 26, 2008 | Palm Tungsten E2 Handheld
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
ASUS NCT-D (90MSV430G0UAY) Motherboard Logo
1,171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
