Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No spark on lawn tractor
The key has'nt turned my lawn tractor over all summer, so I've jumped It using the tractor battery, and thats kept a full charge. Last week I go to start It ( by Jumping ), no spark. I don't believe the 2 problems are related. I think the solenoid is keeping the key from working, but a bad solenoid won't keep me from getting a spark. I put on a differant laminate (coil ), new plug, NOTHING. It's in neutral, everything is disengaged, and don't forget, I TURNED this off the last time I used It, It did'nt just stop running. I even removed solenoid and cleaned mating surfaces with emory paper to be sure of ground. I think something is shorting out the spark or I've got a bad wire. How do I start checking wires? continuity? Thank Guys, Andy . Andrewdms2@gmail.com
  • Andrewdms2 Oct 03, 2008
    The key has to be on for me to jump start it. There is no spark. Andy Andrewdms2@gmail.com
  • Anonymous Mar 29, 2014
    How do I jump the solenoid switches?
  • 21 Answers
Have you bypassed the ignition switch?? if you by pass that switch and you get spark you know its the switch
Posted on Oct 03, 2008
  • sidewinder77 Oct 07, 2008
    is there a fuse blown??
    you should ohm out the ignition switch
    how many wires on your ignition switch(if theres only 2 just connect them together and check for spark with the wires connected) and what color are they or do you know which wire goes to the starter solinoid, if you do put put power that wire and check for spark
    hope this helps
  • sidewinder77 Oct 08, 2008
    forget what about connecting the solinoid wire that would not help.
    you should try and bypass the switch in the on position and check for spark that way
    sorry
Sold wrong battery and crossed terminals
I doubt that jim, but i don't know anyway quicker to kill a charged battery than to hook it up backwards to another battery (sparks you mentioned) try using a spare car light bulb to verify that battery is charged up , also look for inline fuse someplace close to the battery location, you might have blown that , continue using car bulb to "walk" thru circuit to verify presants of voltage (key/starter/dashlghts)
Apr 16, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Craftsman 18.5hp new battery new solenoid will only crank one revalution then quit what next?
It could be several things !! well not the battry !! you can check that out from the list !! sounds like the starter is dragging, you can try to jump it off with a screw driver turn the key on and touch the two srews on the solenoid becareful cause its going to spark a little , check to see if it still drags or it fires right up !? if it drags and turns slow than its most likley your starter ,check and see if the starter geting real hot also ? thats one of the signs that its going out also ,
Feb 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ingnition will not even click. Replaced iginition switch, solenoid and spark plug. Checked seat switch, transmission switch, fuse. Started motor turns when jumped. Battery fully charged. Fresh gas. ...
Hi, is the deck engagement lever off or the pto switched off? If it uses a lever check the switch on the lever. If it uses a pto check the pto switch. Hope this helps, regards Phil.
Jun 24, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Jump solenoid with screwdriver
Turn key to run. Put screw driver to battery cable side while holding the plastic end of screw driver touch other end of screw driver to cable that goes to starter on solenoid and wjth full charge of battery you should have starter turning.
Mar 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Turn key to run and nothing happens pops fuse
Those safety switches you mention above is a good first place to look. Possibly the magnetic switch that makes connection with the battery and the starter needs replaced. When you jumped the starter to turn the motor over did you have the key turned to ignition? No spark can come from a low oil shutdown switch located somewhere on the lower part of the engine (either low oil or bad switch), if the key was on. The switch can be bypassed to test its condition. Keep us posted.
Jul 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an RZT50 Cub Cadet Mower that only starts with jump
it sounds like the starter motor is pulling to many amps for the battery to cope with. if its a 12v system it should not pull the battery down to less than 8.5 volts on cranking if it does the starter-motor is defective you can check this with a volt meeter across the battery terminals and see what it read as you crank the engine. hope this helps
May 12, 2009 | Garden
Will not turn over w key NOW no spark
I hate to sound obvious, but if you are starting it by jumping it, than the problem may not lie in the circut or ignition, but it may be a battery problem. Have you checked the battery to make sure that is a full charge?
Sep 27, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
399 people viewed this question
Top Craftsman Garden Experts
Dwain Pippen
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
