Question about Intel D865GBF Motherboard
Intel D865GBF Ram related questions
Hi all,
i have an original intel D865 GBF motherboard and Intel P4 2.66 Ghz process, i have 512 MB RAM, i want to upgrade my RAM
Here are my concerns
1. Does my motherboard supprt DDR2 RAM?
2. Is there anything like DDR2 and DDR2 SD RAM? or both are same?
i believe i have DDR1 RAM installed in my system as of now, dont know whether its SD or Not
please clarify so that i can buy the RAM which supports my motherboard
Thanks in Advance
Regards,
Nandakumar
    Scholar:
  • 191 Answers
Here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Posted on Sep 28, 2008
Isn't DDR2 240 pin? DDR1 is 184 pin...DDR2 will not work on a D865GBF board. DDR1 memory will only work with this board and you have to use identical pairs for it to run in dual channel mode. Make sure they are in the correct slots for dual channel mode. Max memory for this board is 4 gigs. Use branded memory as generic is junk and may not be recognized properly. I recommend OCZ.
Posted on Feb 25, 2009
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I HAVE INTEL 845GVSR MOTHERBOARD & 2.4 GHZ PROCESSOR & 512 MB DDR 1 RAM ,I WANT EXTEND TO RAM,IS IT POSSIBLE ??
Yes, up to 2 GB as written here: http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
The type of RAM that you want to choose is written here too.
Mar 20, 2012 | Dell Motherboard 51XGM SYS BD GX110...
I does not have my intel mother board cd with me so how can i install my sound device to my system so pls send me installation cd for my mail and my system is d865 gbh 1.4ghz and 512 mb ram processor and i...
First make sure if the board is D865GBH or D865GBF or D865GBR
visit the link:
http://downloadcenter.intel.com/
Select discontinued products. Now you will be able to find the drivers for your board.
Dec 05, 2010 | Intel Desktop Board D865GBF (MBIND865GBF)...
I have intel d865 gbf motherboard.I have installed windows 7. Graphic driver of the motherboard is not working. Messege displaeyd is " This driver does not suport your operating system. Please help me and...
Intel has no plans to develop a Windows 7 driver for your older, discontinued motherboard.
You may wish to use the latest operating system that IS supported to continue using your D865GBF board.
Intel Discontinued Boards Windows 7 Downloads
Mar 06, 2010 | Intel D865GBF Motherboard
I have 512 mb ram, 2.66 2.66 ghz processor, intel chipset Fifa 08 works well on my pc Is it possible to play Fifa 09 for me?
You shouldn't have any trouble.
Minimum System Requirements for Fifa 09.
CPU with 2.4 GHz (single-core)
512 Megabytes of RAM (1 GB required for Windows Vista?)
DirectX? 9.0c Compatible 3D accelerated
128 MB video card or equivalent
(must support Shader Model 2.0 or above)
DirectX? 9.0c Compatible Sound Card
512Kbps or greater
broadband connection for online gameplay
MS compatible mouse
Keyboard
Cheers'
Mike
Mar 03, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D865 GBF system hangs oftenly
Hello,This always happen when the processor is bad or faulty. when the system is working, check if the processor fan is working too, if the processor is working that means the CPU is faulty.leave the system open and power it on to see if it will hang.
Aug 11, 2009 | Intel D865GBF Motherboard
What is the maximum onboard VGA support from Intel D865GBF?
This board supports uses Intel Extreme Graphics 2 for its onboard video memory but even Intels site does not explain how much memory it has or if it shares RAM for video memory. Your manual can be found here
http://www.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
May 12, 2008 | Intel D865GBF Motherboard
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
907 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
