Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F & P won't start Door problem
Hey there, We were having problems with low water, so we pulled the top draw out to check water and cleaned it all out. We put it all back together. Once it was all back we pushed the start button only for it just to beep at us as if the door was not closed properly. Is there a sensor or somthing that is not right. We have looked and looked but can not find anything. Is there a matenance guide or somthing.
Thanks
Mark
markmarmont@yahoo.com.au
  • 136 Answers
Did you hear anything when you close the door? something you will hear a click indicating that the door is closed. try pushing on the door and see if that does the trick
Posted on Oct 30, 2008
Something is draining my battery on my 1998 Cadillac DeVille
I suspect parasitic draw. All vehicles draw some power from the batteries when the car is shut off. Certain accessories such as clocks, radios remote door openers and alarms always need power. The normal power used is called parasitic draw.
It is always a very low draw so it doesn't run the battery down. If you install accessories like shortwave radios or plug things like inverters and portable refrigerators into the accessory socket and operate them too long without the engine running you can drain your batteries to the point where the engine won't start. If there is an electrical short in the vehicle or a malfunctioning accessory it could be drawing much more than its normal load causing a drain on the batteries. If you leave your door open and the inside lights stay on all night you could drain the battery down till the car won't start.
Here's also a good resource for your car specifically on narrowing down the cause of the drain.
Oct 23, 2012 | 1998 Cadillac DeVille
I can't remove the freezer drawers from my Whirlpool Gold Model # GI5FVAXVB02. Called the company and they couldn't help me.
you have a blocked drain,try this,pull out the machine,unplug it,remove the bottom panel,lie on the floor and with a light look up or feel around,there's a nipple that's there that the water drains out of or drips through,i've been removing the nipple,running it under water to clean it,but it has to go back,if you don't put it back you'll have problems,this keeps the warm air from getting into the freezer,before you put it back on get a hair dryer and melt out the ice,just heat up the back freezer wall and then pour hot water down through the back wall,if the water drains out you don't have to take the freezer draws and racks out,they changed them all around and i can't explain how to do it and if you pull it out and don't line the two wheels up correctly the door won't close right,i mark them with a marker before i pull them out,it sucks to do and is very ridiculous,you need a manual just to remove these parts,if this doesn't have a nipple on it and has a drain hose there you can try to clean it out from that end,you can get a piece of 1/4 in water line like they use for the water lines on the fridge,buy a piece and snake it up through the drain hose and then blow through it then flush water through the back inside freezer wall,slime builds up in the drain hose on all machines so once it's freed up it will drain,you might think that if you go from the back you'll push it up into the freezer and it will happen again it won't,once you hit it and free it up it will break apart and every time the machine defrosts the water will wash any parts that is still in there out.i'll try to see if i can find any videos on line for you to show how to remove the shelves and racks and then to line them up again but try going from the back first.good luck.
Aug 10, 2012 | Refrigerators
I have an indesit 1100 washing machine, but it does not take the softener in from the draw. i have cleaned the draw out nad tested the draw over the sink. it seems to work ok but once its back in the...
You need to clean the drawer box top, the holes get blocked and the pressure is only low on the conditioner section..you will need a lengthy object to clean the hole properly
Oct 05, 2017 | Indesit Washing Machines
Top arm does not seem to be going around when diswasher is running. Top shelf articles are not getting clean. Black scummy material gets stuck in the top arm jet.
HI- If you can remove the spray arm, usually they screw or pull off, then put it under the faucet and start picking out all the stuff out of the jets. The best tool i've found for this is a large safety pin, bend a little hook on the end of it with a pair of needle-nosed pliers. It takes a long time to get them all clean (sometimes an hour) but keep at it until you can run water through the center hole and there are no more obstructions. Do this with all the spray arms if possible. The black stuff may be from the bottom of the door. With to door open take a rag and clean under the door and around the frame; I've seen a lot of the gook build-up there. Clean the filter as well if possible. The other thing to check is the water level in the dishwasher. Start a rinse cycle and after it starts washing open the door and the water level should be up near the heating element. If it is too low then the dishwasher will no be able to build-up enough pressure to force the water through all the spray arms. If the level is low you'll probably need to have someone out to replace the inlet valve. And most importantly ALWAYS rinse your dishes no matter what anyone tells you :) Hope this helps.
Sep 24, 2010 | GE Dishwashers
Took tray and grounds tray out to clean and it won't go back in - it is jamming. Have cleaned inside but still stuck. Tried pulling infuser out but this is stuck as well. Appears that central unit has...
I had this problem last night. The infuser was stuck down too low and the tray wouldn't slide in. I got the solution from FIXYA, and it worked for me.
First make sure machine is off at power, then put just the coffee grounds collector and not the whole tray back into place, gently close the door, and then turn the machine back on. At first I couldn't close the door, but I fgured that the grounds collector was a bit too low, so just put something in there to hold it up while I shut the door. Turn the machine back on at power and HEY PRESTO, it all started up again, and then the infuser moved back into correct position.
Make sure you have a cup handy just incase water starts to rinse out.
Hope this helps
Tania
Sep 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water comes out of the soap dispenser its a brand new samsung model # is WF9854RWE i put soap into the dispenser closed the door and when it started to fill with water out of the soap dispenser door water...
Hey im having exactly the same problem with my samsung WF9854RWE and after the load of washing is done when you open the draw water spills out everywhere.
Jul 11, 2010 | Samsung Washing Machines
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Blinking "Normal" button
PROBLEM: STOPPED RUNNING, WILL NOT START AND
CLEAN LED BLINKS 7 TIMES, THEN REPEATS
(WATER HEATING FAULT)
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
Wash pump not pumping water
past the heater efficiently.
See “WASH PUMP WILL NOT
PUMP”.
Door switch not making
contact consistently:
■ Faulty or sloppy door latch
assembly (which can be
aggravated by high door
closure force keeping strike
plate from fully seating).
■ Faulty door switch (high
resistance).
NOTE: Neutral switch on
plastic tub models is only in
series with motor and heater;
other loads are not affected.
1. Unplug dishwasher or disconnect
power.
2. Measure resistance of door
switch contacts while checking
mechanical operation of latch
assembly. Confirm switches not
loose from assembly. Check strike
plate and door closure.
Lack of water to heat. See “WILL NOT FILL OR LOW
WATER”.
PROBLEM: WON’T START AND START/RESUME K
Sep 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Water issue in fridge
Generally, this is condensation of humidity in the air. It is occurring after the defrost cycle. Check your door gaskets and clean or replace. Pull a 2 inch wide strip of typing paper through the gasket area to check for sealing. Oh, and if someone is 'window shopping', that's letting the humidity in.
Dec 19, 2007 | Samsung RS2630SH Side by Side Refrigerator
Water pumping out of draw and trickiling out of door
If it does it when it fulls. You may have something stuck in the fill hose blocking the water inlet..be sure to unplug the washer then Remove the top.. Then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me know if this is it... krazytech
Sep 08, 2007 | Hotpoint WMA50 Front Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
169 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
