Question about Dishwashers
Bad control board
Thanks for helping! How do I test the board to know if its bad? and is it worth the $120. to replace it verse buying a new dishwasher?
  • njpdoes2 Sep 29, 2008
    Thanks again!
Hi again,
Please reread my last posting. I answered these questions giving you all the instruction possible given the limitations of this type of comunication. If you are unsure, you might want to check the Repair Directory for a repareman.
Best wishes,
Posted on Oct 01, 2008
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi again,
The wireing diagram is useually under the d/w. Look for a package behind the kickplate, under or behind the d/w. You don't have to have it. Just follow the power. Test the wires after the door switch (simulating that the door is latched). Test the other end of the wires. Test for power where it goes into a part then where it comes out. Eventually you will find a part where it doesn't come out. That's the part you have to change. A volt/ohm meter is all I ever use and it doesn't take a lot of time.
As far as your second question; that's a comparison worth looking at. It's my personal opinion that with the modern american d/w I'd be glad if I got six years out of it. That gives me a cost of about
$ 100 per year for automatic dishwashing. Less than that and I'd rather try a new part, more and I'd rather invest in a new d/w. I use a similar equation on any equipment. It's personal, you get to make up your own equations in life for every piece of equipment you own. Good luck!
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
The oven preheats to 350 then the alarm sounds the oven shuts down then E-4 is displayed ...why is it shutting down
The research I did says it's either a sensor or control board problem. Apparently people change the sensors and at least occasionally the problem is not corrected. This leads you to a control board problem. The control board is often too expensive to replace verses buying a new oven. I am not an expert, but hope this helps.
Jul 21, 2016 | Kitchen Ranges
Electrolux ewt 905 has no power suppy
Hey i will help you. You need to test it with a multimeter and see if you are getting 120 volts at the control board. If you are getting voltage at the control board i would replace the control board. If you don't have any voltage at the board you need to follow where the power cord comes into the machine and start testing stuff and see where you are loosing the power. It sounds like a loose connection or a bad control board. Test a few things with a multimeter and reply back to me.
Aug 30, 2013 | Washing Machines
LED not working
see this causes and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE Advantium 120 Convection/Microwave Oven
Hello, We have a Kenmore HE Plus washing machine that is 7 years old and it just started having problems today. The issue is that whatever program I put it on, at one point it stops and all the LEDs...
um you can have your issue repaired by a sears service man and part and still come out ahead more than likely your control board is bad it happens bu 250-300 bucks verse 1000 seems well worth is just contact sears and pay the service tech and buy part you wont be sorry its all electronic now had simmilar issue please after your issue is resolve leave me 4 stars to show you care it helps me continue to help people like you and others thanks so much
Sep 02, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a GE fridge model GSH25JSTSS and both the fridge and freezer are not cooling and the front panel is out (nothing lights up anymore on it). I've been told I need to replace the mother board, but it...
You need to test wiring harness and connectors, and control board. (motherboard) seems to have a control board problem.If your not getting 120 volts in the light socket then you have a board problem check for loose wire at the control board.Hope you rate my response.Thanks
Feb 03, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
Need to repair model 20605 washer, motor does not run, told the brushes were bad - replaced still wouldn't run, told that motor control circuit board could be bad - $600 to replace, how do you check a...
Welcome to FixYa.
Sorry to hear about your trouble shooting problems. I hope I can help move you forward in the right direction.
Have you run a self-diagnostic which is built into the Asko washer's control ? Furthermore, Did you initially receive an error code of "F6" ?
What led to the changing of the brushes in the motor, and was the motor windings ohm value checked to confirm or dismiss the motor was worth brushes ? The armature inspected ?
This how to run a fault tracing program ( in the event you don't know )
What you will/should see...
Let me know what you've done or found to this point and I'll try to help in whatever manner I can. It is possible the motor control board is the fault, but there is a means to get to that point first.
There was also a period of time during production some of the controls had the wrong fuse placed in below for memo.
This is not very likely considering the age of your machine, however I felt it was worth mentioning. I'll watch for your next post.
Macmarkus :)
Jan 09, 2011 | Asko W6221 Front Load Washer
I have a HTT-9CB Massage chair that needs a circuit board, (just stoppped running) blown fuse on circuit boar and what appears to be a resitor is burned. In short does anyone know where I can get a circuit...
Test the resistor for continuity if it has a continuity readind with the power off then it is bad, you can get the replacement parts at radio shack and change the fuse and the resistor out with a soldering gun.
Oct 17, 2009 | Interactive Health Human Touch Black...
Heads destroyed... is it necessary to change controller board ?
Part 1: No (to my knowledge)
Part 2: Test equipment to do that test would be expensive to have for one fix.
Part 3: If you can identify the controller board as being bad, then yes. If you can't identify, then why change it?
After all is said and done, is it worth fixing? I fixed a printer for my office, it took a long time to find the replacement parts, but I got a $600 printer for about $140 in parts and labor... so in this case, it was worth it. Good luck.
Mar 06, 2009 | Canon PIXMA MP750 All-In-One InkJet...
LCD Panel CHange
Typically if the panel requires changing, it is less expensive to replace the entire unit. Why do you think the panel is bad? Unless it has been dropped, it is rare for the panel to fail.
May 13, 2008 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
