Im plugging my flash drive into the usb and nothing is coming up. this one works in other computers but not this one
  • Computers & ... Master
  • 787 Answers
For starters, what is the operating system of this computer?
Windows XP will recognise flash drives, 2000 seems to recognise some but if you have 95, 98 or Me you need to install a driver for the drive. The manufacturer of the drive may not even supply one.
Posted on Sep 28, 2008
A problem occurred during hardware installation. Your new hardware might not work pen drive 8GB
hi! can u help me? i bought usb flash drive yesterday hp 8gb and it's properly working, when i create bootable usb im in diskpart in command promp and my computer got freeze not responding, im in a computer shop that's why i remove my usb flash drive and just went home. when i plug the usb it says a problem occured during hardware installation. i know there is the connection about diskparting the usb yesterday. i troubleshoot my usb flash. i go to device management and uninstall the usb drive and scan plug and play, but its not working it always show the yellow mark. even i update the driver its not working. what should i do? i hope u can help me :( here is my email just incase u have a solution for me. Thank you very much!
Feb 16, 2012 | Electronics - Others
How can I make my USB flash drive work again? I asked this question before but I have a Mac, not a PC. no light turns on, nothing comes out in the computer, I have tried it on different computers, i'm...
An USB flash drive is made out of a memory and extremely simple controller chip installed on a tiny board with a connector.
If the drive is completely unresponsive then the chip died. This is terminal, nothing can be done to save it or to recover what was in it.
Aug 11, 2011 | Computers & Internet
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have nothing on my 8gb sandisk cruzer usb flash drive but it says i only have a tiny bit of space left on it and it says im using 7gb. i want to put music on it but it wont let me.
Plug it into your computer and format it, that should give you all your space back. If you need help with this please just let me know.
Dec 27, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My Sandisk 4GB Cruzer wont work ... When i conect mu USB it wont flash and a bubble comes up on my computer saying unkown device please can anyone help me thank you,. And im on windows xp..
Try plugging it to another USB port on your computer, preferrably a rare one.
Also, try plugging it to another computer.
If none of the above worked, I'm afraid the pendrive is damaged and have to be replaced.
You can take it to a special lab that specialized in data restoration in order to take the data out of it...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards and good luck,
Dec 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My scandisc was in the usb drive working fine all at once the light on the scandisc went out and now it does nothing i need help to get the data off of it stored for work computer does nothing when I plug...
Have you tried plugging it in another computer? If it worked, then the USB port on your computer (the one the scandisc was plugged into) is burned. If it doesn't work in the other computer, then the USB drive's chipset is burned ... unfortunately, data recovery is very difficult, but there are specialized companies that do this.
Aug 24, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I didn't click safely remove hardward device when I took out my flash drive, now it won't recognize my flash drive at all. It will work on other computers so I know the flash drive doesn't have a problem.
This should have nothing to do, with the safely remove hard ware option.
Plug the USB key back in and check your device manager for conflicts? If the usb key is listed as a conflict, uninstall it and then reconnect your usb key.
Also, is this computer on a network... if so, it may be a coincedence, and a entire issue all together.
Put it this way, if the USB ports on your computer still work with other devices, and your flash drive works with other computers... nothing is wrong with either. Something is just probably conflicting with it
Aug 24, 2008 | Computers & Internet
USB not recognized and im confused!
most likely the flash drive is defective.
if it giving you the same problem on other computers, thats most likely the case
Jul 31, 2008 | Electronics - Others
Flash disc ( stick ) will not work
Some flash drives have a case that is too fat to be fully inserted in usb connector of some PCs, I have has the same problem, try a short usb extension cable, worked for me.
Oct 21, 2007 | Lexar FireFly 2GB USB 2.0 JumpDrive
Computers & Internet Logo
David Payne
David Payne
