Question about Panasonic Lumix DMC-TZ1 Digital Camera
Please turn camera off and then on again
Whenever i open my camera this message is seen on the screen " please turn camera off and then on again" I cannot use my camera anymore. Pls help me to solve this problem.
thanks
  • sevcheto1 Dec 09, 2008
    I have the same problem!Can I fix it by myself?
SOURCE: Camera powers on, then off
The same thing happemed to me and when I turn the caera off the lens won't go back in. After a while I get annoyed but its not my fault i think the camera does not like me?!? Solution: Just let the camera be and then it will maybe be better than before. Trust me I did this and it works but still the lens won't go in?!?!? LOL LOL
Posted on Apr 22, 2007
SOURCE: Message - "Please turn off camera and turn on again"
take it a basketball court and try a slam dunk it ...that should break it all apart so u dont need any tools at all then try putting it back together with just your fingers and crazy glue. If still shows the error message attach it to the side of the space shuttle on its next orbit. hope Ive been some help CrazyLarry
Posted on Jun 26, 2007
leethedeuce
  • 4472 Answers
SOURCE: Panasonic DMC-LX1 Digital Camera
Your camera is then in need of service. If you need any further assistance please let me know.
Thanks,
lee
Posted on Jun 20, 2008
  • 11967 Answers
SOURCE: message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
Posted on Aug 13, 2009
dnewcombe1
  • 1564 Answers
SOURCE: When in a record mode LCD says to
You are experiencing a media miscommunication. This due to low or incorrect amount of voltage to the cameras coding circuits.Take a Q-Tip "dampened" with rubbing alcohol and clean inside the battery compartment well. Do the battery contacts and the charger the same way. You should be all set after this. Dana
Posted on Aug 31, 2009
Error in digital cam that please turn off the camera and on again
smeone had gifted me panasonic digital cam DCM LZ8 bt when i turn it on an error accurs that please turn off ur camera and then on again
please help
Jan 01, 2010 | Panasonic Lumix DMC-LZ8K Digital Camera
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Lens is stuck and wont move. on the screen it states "Turn the power off and on again" help pls? Was working just fine and then started with the lens not opening...I opened manuelly and now it wont't take...
I agree that the camera needs to be sent back when this happens.  I have seen people suggest pulling on the lens (a bad idea) and smacking the camera / rapping it upon something (an even worse idea).  Not only will these options often fail to work, they will damage your camera further and void your warranty (leaving you stuck with a broken camera).  If you find a fault in this (or any) camera, DO NOT HESITATE to either send it back or demand a refund in full.  The lens sticking IS A FAULT IN THE CAMERA, not something the consumer should have to fix on their own.
Also, for the record, if Solution #1 (posted by "geragodina") is really a copy/paste of a LiveAssist Chat, please be aware that "Patrick" was not an actual person, it was an AI chatbot (if you need proof, try visiting jabberwacky[dot]com).  I have been writing AIML for various chatbots for years, and am amazed that this site charges for "Live" Assist Chat when they are using scripted chatbots.  Save your money and ask real people.  Remember, chatbots are only as smart as the people who program them.
Dec 31, 2008 | Sony Cyber-shot DSC-W170 Digital Camera
Outlook problem!!
uninstall office completely, restart your system and reinstall office completely...
Mar 15, 2008 | Microsoft Office Outlook 2003 for PC
My iphone 1.1.1 version was locked after we upgrade it. we tried upgrading bec. of the restore option in the itunes. but when we connected it again w/ itunes, the restore doesnt work.help help!!!pls!!! now...
If you have an unlocked pghone and whilst on itunes it asks you to update to tht version you must click nor or else it will lock i don't know how to fix this problem you will need to contace apple or get it unlocked again.
Jan 21, 2008 | Apple iPhone Smartphone
I get a buzzing sound
Hello Rrosario35, This problem is related to the lens assembly. The camera will check if these work properly when it's being powered on. If something goes rong here it will turn off or display you some error messages. This problem occures when some of the lens mechanisms get out of place and jamms or damages other components. As the lens assembly is a very delicate mechanism I would suggest you to go back to the service center that fixed it the first time and ask them to check it. Don't try to power the camera on anymore because the lens assembly could be damaged further or beyound repair if the servo-motors are trying to alling the lens something jamms them and not allowing them to move properly. This will force the servo-motors and they could damage other components or themselves. It could be fixed, but don't force the camera to work anymore for the time being. Please post back if more informations are required.
Mar 22, 2007 | Kodak EasyShare V570 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
