Question about Maytag Kitchen Ranges
MY maytag oven just stoppped while I was baking the clock display now says off. the cook top works but the clock or the oven will not work. It did come up with a f9 code. Is there a reset code ?
  • 213 Answers
SOURCE: F9 Display in Model MGR5770ADB Gas cooking range
f-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
Posted on Nov 27, 2007
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 247 Answers
SOURCE: Maytag Stove Model MER5570BCW purchased
when it says F9 on the screen it means ther is something wrong with the Door Latch - Check door latch, switches and wiring. I would start here first.
thank for using fixya and let me know if you need any more help.
Posted on Dec 19, 2008
  • 2110 Answers
SOURCE: F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Dec 23, 2008
SOURCE: jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Posted on Jan 16, 2009
Oven controls not working , just clock on display
Good Morning kJordan!
FixYourBoard can likely help you with your unit. They'd remanufacture your part in 1-2 days, fully test the unit.. and back their work with a 2 year warranty.
Mar 29, 2017 | Kitchen Ranges
Whirlpool oven/stove with accubake. The cook top works with no problems the clock and display work with no problems. The oven does not work at all no bake no broil. Got it to work a couple time by...
Take a look at the oven ignitor,you might have two.The one at the top is the broiler ignitor.And the one at the bottom is your oven ignitor under your lower oven plate.
Feb 21, 2013 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
My oven comes on and reaches the right temperature but then it starts beeping and shows F-2 or an F-4 in the display window. Then it stopps cooking.
Your temperature sensor is inside the oven in the top rear section. It is metal about 3 inches long. You can remove it from inside the oven. The F2 and F4 codes is a bad temp sensor.
Nov 24, 2009 | Maytag CWG3100A Gas Single Oven
Nothing heats up on my maytag glasstop but the digital display
an electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Jan 22, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag cook top too hot!
Remove cooktop and check to see how much insulation is below the top, on top of the oven cavity, You may want to install some more insulation. The specs for this range probably allows this to happen. you should not put anything on the top after cooking in the oven, as glass breakage may occur.
Dec 04, 2008 | Maytag MER5775Q Electric Kitchen Range
Simpson Atlas Apollo ceramic top stove, Digital clock etc. Just installed. No user guide to set clock etc. Oven wont work, suspect clock needs setting. Can I get a user guide?
Hello, I think I have the same oven as you, and yes the oven doesn't seem to work unless the clock has been set.
On my oven, there are 4 buttons and a dial below the digital clock.
To set the clock, you need to turn the dial whilst holding any two of the 4 buttons down.
For me it's a two handed job.
Nov 30, 2008 | Kitchen Ranges
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Kitchen Ranges Logo
47 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
