NEC-3480 TV Wont tune
I have a NEC N-3480 TV, with a remote which my daughter found, and pressed all the buttons, now my TV is blank, and no button on the remote will scan for new chanels, How do I get it to scan, there are no buttons on the tv itself either.
  • 55 Answers
for tune your grundig you must use remote control
Posted on Dec 10, 2007
I have an Orion Model TV2521. How do I turn on "closed caption" without the original remote? It broke and the tv is now using a universal remote. I tried the onscreen menu on the TV,but did not see an option to perform this task.
Posted on Jan 31, 2008
SOURCE: Remotes won't work with Sanyo Tv
12345gut 7twryt iouoiopu p0ouhjbhb vytv6frsawzs sxfhjkliyffvvvnjhukjkjhiuhj hggggggghjyut7u 67 y 69455230528455659+56525555555555555555555hju khk*********mjinjknkjnjk89wdeqqzaesfbh jj jtfvghtrrgh bhhjvugjhiuf yuh uh iu iiiih ui u u uyyyyyyyyyyyyyyyyuyuiy7htgg5555555bhh dhju yg ugsgxxh yusyyhyhzghgxtyc gfyt syu6780
Posted on May 18, 2008
SOURCE: tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Posted on May 19, 2008
SOURCE: How to tune
Posted on Jul 16, 2008
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
Nov 10, 2013 | LG 32LD350 32 in. LCD TV
Nec tv RD1113e 79644901 cant tune stations, no menu button on remote
If there is no Menu button on the front panel of the tV, it will be difficult to get an auto tune function to this set. Try to muy one universal remote contol, which have setup codes for your NEC Tv.
Mar 01, 2012 | Televison & Video
NEC FS5195 TV instruction manual for tuning TV stations and connecting VCR & Set Top Box
No manual found. But, I found this post on the web....
"if you press the "menu" button for 3 seconds you can set it up automatically (grey button on the lower right) and have 1 additional menu by pressing menu again. Hope this helps!"
Oct 12, 2010 | Televison & Video
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
Lost remote need code for universal remote control.
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your NEC from the list which follows:
    030, 056, 019
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
May 11, 2009 | Televison & Video
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Trying to Tune local channels on a NEC TV Model #4856 using the NEC remote control # RD111OE... Can anyone help!
Hold down both the PRESET-HOLD buttons at the same time
Press again until AUTO is displayed.
Press ^Vloume to start automatic search
Dec 11, 2008 | Televison & Video
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Older NEC TV mising a manual
Manual missing here as well... what i found out.... if you press the "menu" button for 3 seconds you can set it up automatically (grey button on the lower right) and have 1 additional menu by pressing menu again. Hope this helps!
Dec 01, 2007 | Televison & Video
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
