Router has 4 ports and wireless capacity . Only 2 desktop systems are connected to the DLINK Router . The purpose is to be able utilize the internet connection provided by our dsl modem simult. on both systems.
Problem : Every couple of hour we have to unplug the router and plug it back in to restore the connection to both systems. Basically "Reset" the router. Something has to be wrong. CAN YOU PLEASE HELP ???????????????
Best regards,
Tim & Maria
Supposedly the firmware 1.03 was suppose to fix this. However, I still have the problem and when i try to unplug the power to the router and plug it back in, then it often times just lights up all the lights solid and refuses to work. I have to unplug it again and again to get it to work.
It usually will work for a few weeks at a time then have a really bad day where it locks up every 10min to an hour. Gets really annoying.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
I have the same problem and it "is" very frustrating.
same problem and i'm on 1.04 of the firmware on hardware A1
Ditto, from the get go. Support worthless & rude, saying only 'It should work'. Not even using wireless features, but merely 2 desktops to share one DSL line. Have tried every suggested remedy but none have solved the problem. Plan to upgrade soon, and definitely not with a D-Link product.
I have the same problem. The Hard ware revision B1 and firmware 2.02; Any solutions for this problem other than dumping it in the bin?
Same problem. It's been happening for a while and I'm frustrated too. It seems to happen most under high load. I have a WBR-1310 H/W ver A1 annd firmware 1.04 which is the lastest available although it was released in March of 2007!
