Question about Averatec 3200 Notebook
Lash up for external monitor
My Averatec 3200 has a broken monitor screen and I'm going to hook it up to another external monitor. What I need is the physical lashup and confirmation of function f5. Thank you in advance, Steve Smith
  • 417 Answers
Depends on the monitor, some monitors have a wired in cable with a multi pin connector fitted others have a mutipin socket in which case you will need a monitor connector cable. Industry standard is a 15 pin VGA connector cable which should be available from any computer supplies store. Connexion should be simple plug in at each end and often the act of plugging in the cable will cause the image to display on the monitor (providing it is already on standby) but if not pressing Fn and F5 should do the trick.
Posted on Sep 28, 2008
My averatec laptop will only power on to a black screen but it still sounds like its booting
1) Laptop on use a flashlight, and shine it at the LCD screen. Shine at various angles.
Do you see faint images?
2) You can also plug in a VGA monitor to the back of the laptop, (Laptop OFF, monitor off), and toggle over.
(It can be a VGA monitor that looks like a small TV {CRT}, or an LCD flat screen that has a VGA cable attached)
Plug the VGA monitor's cable into the blue VGA port on the left side, of the Avertec 3200 Notebook PC.
(Example of VGA connectors,
Turn the VGA monitor on. Give it time to 'come to life'.
Turn the laptop on.
Are there graphics on the external monitor? If not press, and hold down on the Fn key, (Blue Fn next to the CTRL key), then tap the F2 key.
(The F2 key is the toggle over key for an external monitor. You can use the laptops LCD screen, or it's screen, and an external monitor)
Graphics show on the external monitor? Your graphics chip is good.
Problem is with the screen Inverter, or the Backlight.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and the Backlight.
90 percent of the time the fault is the screen Inverter.
The Display Assembly essentially is;
1) Top cover of the laptop. (Display Cover)
2) LCD screen
3) Display Bezel. (Thin plastic frame in front of the LCD screen, and surrounds the LCD screen)
4) Inverter
5) Backlight
6) LCD screen frame
With the Display Bezel removed, the screen Inverter should be at the bottom/front.
This is an example of a screen Inverter for an Averatec 3200 from a quick search,
I haven't worked on an Averatec 3200 Notebook PC before. I have worked on 100's of other laptops.
The sequence for removing the Display Bezel follows a pretty standard approach.
Looking at the Display Bezel I see four screw covers. (I'm looking at a PDF Users Guide)
One at the top Right corner, one at the top Left corner, one at the bottom Left corner, and one at the bottom Right corner.
These screw covers made of a rubber-like material. (Synthetic rubber) They are slightly rounded on the top. They have a type of rubber cement that holds them in place.
I use a computer pick to gently pry them off. If you carefully pry each screw cover off, and set them down sticky side up, (Screw side), you can usually reuse them again.
Screw covers (4) removed, use a Philips head screwdriver, and remove all 4 screws.
The Display Bezel will still be held in place. It has plastic tabs on the outside edges that snap into the Display Cover. (Top cover of laptop)
A fingertip is used on the INSIDE edge of the Display Bezel, next to the LCD screen.
(WATCH your fingernails against the LCD screen)
The fingertip raises the Middle/Inside edge of the Display Bezel, just slightly.
Now use another fingertip on the opposite side. Raise the Middle/Inside edge.
The Display bezel should start 'popping' out. (As the plastic tabs release they make a popping, or snapping sound)
To illustrate this technique further,
(One more, to show you where I believe the screen Inverter is for the Averatec 3200 Notebook PC, and what an average screen Inverter circuit board looks like,
When the Display Bezel is loose, you slide it to one side a little to ease it around, and off, of the cover latch.
The cable connectors going to the screen Inverter are shaped differently from each other, so that when you go to reinstall them, there is no chance of mixing them up.
With the tools you have available, I would replace the screen Inverter ($7 plus shipping), and see if this repairs the problem.
If not the problem is the Backlight. Most of the time you have to buy the LCD screen, as the Backlight is an integral part of it, and should be replaced by a professional.
[ An LCD screen is composed of layers. The layers are held together in the correct alignment by the LCD screen frame.
This alignment MUST be aligned as it was from the factory.
This gives you an example of replacing a Backlight,
Make a mistake here, and you can throw your LCD screen in the trash ]
For additional questions please post in a Comment.
Aug 21, 2011 | Averatec 3200 Notebook
I have an averatech 3200, the screen suddenly become dark, after reboot, it will only bring the Averatec logo page, and then it will remain dark. Is there something wrong with the monitor?
If you are getting the logo in the beginning that means screen is fine. Reset defaults for BIOS and try booting your computer with the help of disk.
May 24, 2010 | Averatec 3200 Notebook
Screen wont light up.
Try testing the system on with an external monitor if it displays then the screen LCD is faulty and need to be replace with a new one.then the best thing is to get the screen been change .
rate this solution..
May 07, 2010 | Averatec 3200 Notebook
My Averatec laptop's screen is going out and if
Seems to me the inverter is gone if you replace the inverter it will work like a charm
Dec 31, 2009 | Averatec 3200 Notebook
Blank screen
Look very closely at the screen when its on, see if you can see a faint image in which case the ccfl tube in the screen will be dead. Also try the laptop on an external monitor.
Otherwise if you know what your doing, remove the battery, hard drive, optical drive, all but one stick of ram, modem/wireless card and try again. There is a small chance it will be the cpu or motherboard.
Jun 16, 2009 | Averatec 3200 Notebook
Want to replace Averatec 3200 Laptop Screen
Do you know for sure the LCD screen and not the video card is faulty?
You may find it cheaper to repair the LCD screen than replacing it.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 16, 2009 | Averatec 3200 Notebook
Black Screen
The first thing I would do after turning the computer on is check to see if the video output is being directed to the LCD screen. The output can be directed using the Fn key along with the key with the picture of the 2 monitors on the Function keys at the top of the keyboard. Hold down the Fn key and tap the other key once or twice,
Next, hook the computer up to an external monitor. Do the same thing with the Fn key to see if it's the LCD screen.
If the external monitor works, then you haven't correctly hooked up the LCD screen or it's bad.
Feb 05, 2009 | Averatec 3200 Notebook
Averatec 3250 laptop
I think you may need to repair your installation of windows XP or if that doesnt work, just reinstall it fresh.
Nov 18, 2007 | Averatec 3200 Notebook
Problems with lcd screen
Try hooking up an external monitor. If you see the same thing, you probably have a video card issue. If not, it's probably a problem with the LCD.
Let me know if I can be of further assistance.
Nov 08, 2007 | Averatec 3200 Notebook
Averatec 3200 Dark screen
try connecting an external monitor. i suspect your monitor screen's back-light to be expired
May 23, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
60 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
