Internet connection i have p-iii and usb port is there but i do not have lan card , i have taken bsnl broadband connection how can i configure connection and use internet with out lan card pl.help
  • 75 Answers
Plug the modem through the USB cable given to the usb port and install the required driver from the given CD..If usb cable or CD is not given approach the BSNL office and ask for it..Else u can buy a lan card whick cost abt 100 i think..
Posted on Sep 28, 2008
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
I have a router and switch d-line brand,how to bsnl broadband connection give to multi user
CONFIGURE UR ROUTER WITH BSNL. THEN CONNECT SWITCH TO LAN PORT OF THE ROUTER.CONNECT THE MULTIPLE PC TO IT
Dec 22, 2012 | Computers & Internet
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Linksys Wireless-G BroadBand Router
Who is your ISP (Internet Service Provider)?
If you're using a Cable provider, do the ff. steps. (For Linksys router)
1. Launch Internet Explorer and type http://192.168.1.1
2. It will prompt you for username and password. Leave it blank on username and type admin for the password.
3. Under SETUP tab, click the sub-tab MAC Address Clone. The click the button Clone My PC's MAC. Then click on Save Settings.
4. Unplug the power to the modem and the router for 30 secs. After that, power on the modem first, wait for all lights to go solid then power on the router. Check if the internet works.
Hope this helps.
Jul 19, 2008 | Linksys Wireless-G Broadband Router
Siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
BSNL Broadband connection
In brief yes. 2 possible ways:
1. Use a router; or
2. Configure 1 of your PCs to be the Default Gateway and enable Internet Connection Sharing (this is where the single user broadband connection must be plug in). If your modem uses USB connection to the PC (Gateway), use the LAN card IP add as the Default Gateway of the other PCs in your network. If your modem uses the Ethernet port, you need to install a 2nd LAN card on the same PC and do the same configuration.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
