Question about Mitsubishi WD-52725 52". Rear Projection HDTV
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
PICTURE IS NOT ALIGNED HAD TO TAP TV TO GET IT CORRECTED. NOW THE TV WILL NOT POWER ON? THE GREEN LED ON PANEL FLASHES A COUPLE OF TIMES ONLY. I HAVE THE MITSUBISHI WS-65807.
  • 927 Answers
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Posted on Sep 28, 2008
SOURCE:
Tv screen is warped on edges. what to do?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65807 65" Rear Projection...
PICTURE IS NOT ALIGNED HAVE TO TAP TV TO GET IT CORRECTED
since you have mentioned that you first tap the tv set for it to work well, it has obviously loss connection/ cold solder... check for cold solder and reheat it, this will solve your problem...
Sep 28, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws 65807 sound with no picture
push qv and 9 on your remote and a screen will come up and follow the directions to correct your problem.
Jan 05, 2008 | Mitsubishi WS-65807 65" Rear Projection...
convergence problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 06, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 problems
You need the two convergence IC's replaced part# STK392-570. About a $300-$400 repair.
Aug 23, 2007 | Mitsubishi WS-65807 65" Rear Projection...
WS-65807 picture goes black when using HiDef Signal
Tank, If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue? please let us know..
Jun 11, 2007 | Mitsubishi WS-65807 65" Rear Projection...
TV Image bending
maybe you have a magnet near it?
Feb 26, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
