Question about NetGear WGR614 Router
My Net Gear WGR614V6
Won't work anymore. It's been a while since I have used it.
I don't want to get another one yet. I want to fix this one if I can.
  • shacksta Nov 22, 2008
    my router seems to have given up. computer works but when i want to connect thru the wireless using my laptop the connection keeps on dropping off.
  • Carl Navarro
    Carl Navarro May 11, 2010
    What's won't work? Does it light up, do you get an IP address when you plug a computer into it?
  • 6,487 Answers
IF the router stop working the first thing that you can do is to reset the router by pressing the reset button for 15 seconds while the power is ON then after that unplug the power for 5 seconds and then Run the Installation for the router to reconfigure it back but if you don't have the CD you can contact Netgear support for that so they can walk you through with the process....
Posted on Oct 22, 2008
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
Nov 07, 2013 | ASUS Computers & Internet
Tip
Aerus Electrolux: Don't Void Your Warranty
Aerus Electrolux Warranty
Aerus carries a great warranty on their machines, up to 20 years limited on top of the line models. However, there are some things that WILL void the warranty. The following are probably the most common.
Use of generic/made-to-fit bags. There’s a reason genuine bags are strongly advised for use with the Aerus and previous Electrolux vacuums, and it’s not just the strength of the bag. Fine dust particles will get through generic bags and result in a damaged motor.
Vacuuming wet carpet and liquids. Although you may try to make sure you don’t use your vacuum on liquids, children, other family members, and/or house cleaners won’t necessarily be as careful/caring. If kids notice the vacuum doesn’t work anymore, they may try to hide the evidence, thus you may not know about the problem.
Keep in mind that if you have your carpet steam cleaned, it can take a week or more to thoroughly dry. Vacuuming during this time will result in water/mud getting into the motor, ruining it almost immediately. A wet bag will also usually break open, sending contents through the motor. The motor will have to be replaced, but it won’t be covered by a warranty.
Dismantling of vacuum by unauthorized persons. If you’re having a problem with your vacuum, and you think it’s an easy, quick fix, don’t. You may get it fixed, but this will void the warranty for future problems. It’s simply not worth it.
Commercial use. The Aerus commercial upright is made for tougher work, but only carries a one year limited warranty. Even though your machine may have a longer, better warranty when used properly, using it as part of a cleaning or similar business voids the warranty. Solution; Don’t do it.
Aerus Electrolux does NOT warranty machines sold over the internet, such as on E-bay. Only those purchased through an authorized franchise or representative carry Aerus' warranty.
Be aware of your machines’ capabilities and warranties. An Aerus Electrolux owner has made a wise investment in a top-of-the-line home cleaning system and generally desires to maintain the system in prime working condition, with full benefits.
Contact Aerus for additional information. You can find a local shop/consultant through their home page: http://aerushome.com/
on Aug 22, 2010 | Vacuums
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a 2006 Dodge Caravan. The lights on the dash started flickering and the radio stoped working intermittantly. It won't start anymore and the power windows and locks don't work. We replaced...
did the battery check to be good? are the connections on the battery tight and clean? if so you may be getting a bad body control module , it controls power and ground to the systems you are having problems with.also check the ignition switch to see if you are getting power out of it to power the vehicle up.
Aug 08, 2011 | 2000 Dodge Caravan
Failed smog test 92 toyota camry repairman says he thinks both the catlytic converters are fried and just the parts are$ 1,000, That doesn't include the labor. The chaeck engine light has been on...
I have heard of people removing the plugs in the converters and removing the platinum completely and reinstalling the metal plug and the result being a pass in the air care test.... Let me know if it worked for you
Jul 19, 2011 | Toyota Camry Cars & Trucks
The CD input on my Ampeg BA 115 works, but the 0db and -15db inputs don't. This happened immediately after using the CD input. Quick fix, or repair shop? Thanks.
Sounds like a repair shop job to me. Inputs on a amp have resistance thus there must be a issue inside hence 0DB to 15DB if you go higher well that input thus would not work anymore.
Repair shop would be your best bet for this amplifier. Quick Fix would be unplug it and plug it back in and praying it resets but that won't happen.
hope this was of some help, if not I am sure others will chime in with there 0.2 cents.
Regards
Rulds2008
Jun 15, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Do I need a driver for my sanyo vpc 5885 digital camera because it won't download pictures to my computer via USB anymore. It turns on and then as soon as I push "set" for the PC the lense...
Easiest solution is to get a USB card reader and then use that to transfer the data - the PC will just see the card as an extra drive.
Jul 13, 2017 | Cameras
I have a minolta maxxim digital camara. when i go to shoot a pic it locks and won't take a pic. is it worth trying to fix? I have 2 lenses
Hi, It's hard to say if it's worth it to fix as I can't say how much you value the camera and how much the fix would cost. My suggestion would be to talk to a camera repair specialist, although I don't know where you live, I'd suggest Gus Lazzari who's based out of California. If you need anymore help let me know =)
May 11, 2011 | Minolta Maxxum 7000 35mm SLR Camera
NetGear WGR614 Router Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
