Question about Mitsubishi WS-65807 65" Rear Projection Television
PICTURE IS NOT ALIGNED HAVE TO TAP TV TO GET IT CORRECTED
WHEN I TURN THE TV ON THE PICTURE IS NOT ALIGNED PROPERLY. I HAVE TO TAP OR GIVE IT A LIGHT BANG SO THE PICTURE WOULD GO BACK TO NORMAL. TODAY I TURNED THE TV OFF FOR A COUPLE OF HOURS AND WHEN I WENT TO TURN IT BACK ON, IT WON'T TURN ON?
    New Friend:
  • 50 Answers
Since you have mentioned that you first tap the tv set for it to work well, it has obviously loss connection/ cold solder... check for cold solder and reheat it, this will solve your problem...
Posted on Sep 28, 2008
Hi, I have a Hitachi 53 UDX that was working perfect and then I turned on my system which turned on the tv which came on, but then screen went out....Now I have a squashed looking oval picture that comes...
Have you checked all of your cables to ensure all are connected properly and are tight? If you disconnect your 'system' (which I'm guessing is an audio system?), does the TV work correctly?
Sep 02, 2011 | Televison & Video
My screen is blinking consistently every couple seconds (on and off), I've read your solution about the 'trimpots'. The audio is fine. We opened up the back of the TV and couldn't find anything that can...
It is my professional opinion is to have a technician come out and diagnose it properly. I have repaired several of these models with an intermittent short in the picture tubes. You are correct questioning "How could they get out of alignment"...They DON'T. When the G2 or screen controls have to be adjusted it is to compensate for the picture tubes getting weak. Sony did have problems in that year with bad tubes.
Nov 27, 2010 | Sony KP-57XBR10 57" Rear Projection...
On the right side of the screen it is turning red and is not aligning properly looks like it is trying to go 3d. what could cause this?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Hitachi 46F500 46" Rear Projection...
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Good Day;
Mitsubishi WS-55315 audio no picture
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Sep 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
