Question about Sony Cyber-Shot DSC-S30 Digital Camera
Stuck on PC Mode
When I turn on the camera the PC MODE comes on and does not turn off not allowing me to take any stills.
  • howardsend1 Feb 24, 2009
    Same Problem, the PC mode - USB blue field wont go away
    Genius:
  • 1,447 Answers
Hi-
Press the power button/switch for 5 seconds, if nothing happens remove the battery. Try powering it back on after a few minutes.
Hope this helps
Posted on Sep 28, 2008
My EX-Z335 is stuck in Easy Mode?
Turn off the camera then plug into Pc then switch on. then see if its not in easy mode.
Sep 20, 2012 | Casio Cameras
Lense won't come out
Check to make sure the batteries are okay,and what mode your in because some modes will not allow the camera lens to come out
May 05, 2012 | Sanyo VPC-S120 Digital Camera
My screen is blank (white) and has USB on the upper left corner... i lost my usb cord and it wont let me take pic's or use any of my buttons. What should I do?
Try taking the batteries out for about an hour, put them back in and try it. It seems to be stuck in USB mode which can only happen with a supply voltage of 5 volts coming IN the USB socket. Hopefully that will allow it to turn on in camera mode again.
Dec 05, 2010 | Fuji Finepix J50 Digital Camera
DMC-TZ5 is stuck in USB mode
Try a total reset on your camera/?
Apr 03, 2009 | Panasonic DMC-TZ5 Digital Camera
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
HHD Error
I fixed my hdd error by connecting it to my PC while in camera mode (which still worked) versus video mode and that allowed me to browse both still and video images. Afterwards the camera hdd error cleared and I did not lose any files.
I think this was originally caused by removing the camera from my pc while folder was still open. In the future, I will stop the device using my pc before remove cable.
May 23, 2008 | JVC Everio GZ-MG20 Camcorder
HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Jan 13, 2008 | HP Photosmart M425 Digital Camera
Camera-video mode
Is it a switch or a dial? have you tried new batteries?have you removed them and let the camera sit with the batteries out over night? The button or mode switch could be bad.
Apr 09, 2006 | Fuji FinePix 2650 Digital Camera
Sony Cyber-Shot DSC-S30 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
