Question about LG 42LC2D 42 in. LCD HDTV
Problem with monitor
My monitor is showing frequency outof range what can I do?
    Scholar:
  • 191 Answers
Goto the safe mode and uninstall the video drivers and then restart the system normally and then reinstall video drivers..
Posted on Sep 28, 2008
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    Frequency out of range 11khz/ 119khz message
    The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
    Jan 12, 2010 | Envision H191W Monitor
    My monitor says "out of range" H. frequency: 96.4 Khz V. frequency: 119.6 hz
    You have to configure your monitor turn it down the frequency of your monitor range
    Jan 07, 2010 | Office Equipment & Supplies
    I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
    This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
    Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
    View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
    view sonic -E70fB monitor displaying H.V frequency out of range
    Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
    Monitor displays Msg. frequency out of range, screen is black
    Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
    Mar 31, 2009 | Compaq Computers & Internet
    Out of frequency range set lower resolution
    reboot the system by pressing F8 if your using windows OS and select last good configuration.
    you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
    hope this helps, please rate.
    Feb 06, 2009 | Compaq Computers & Internet
    Out of frequency range set low resolution or refer monitor manual
    TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
    Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
    LG 42LC2D 42 in. LCD HDTV Logo
    49 people viewed this question
    Computer Repairing
    Computer Repairing
