.msi I have 1 click registry cleaner. It found all these .msi files which it said were removable but not safe to do so. They were all associated with drive : (dvd-cd).You said install another operating system........OK....so is there a problem leaving these on the system? Or should I delete them?
Are you saying it should be left alone? Why does it come up as a problem in the scan?
Posted on Sep 30, 2008
  • 4,338 Answers
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Programs cannot be installed, repaired, or updated if the .msi file is not found.
Posted on Sep 29, 2008
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    Tip
    How to Recover Your Computer from Virus Attack {XP ,VISTA ,WINDOWS 7 ,Etc }
    Software 1:DiskHeal
    download
    this software is used to Restore the
    A:folder Option (Hidden files option restore)
    B:C:, D:, E, F,_ _ Etc Drive not opening when double clicked from "MY Computer" Pendrive not opening etc.
    C:Task man not openning (ie to recover Task Man is disabled by your ADMINISTRATOR error")
    and more............
    D:Restore Registry Editor
    Software 2:Autorun virus removal (can remove autorun virus form your computer)
    download
    A:restore Exe file error's
    B:anti-virus not installing {some viruses block installation of Anti-virus software } provide solution for these problem
    C:can repair Safe Mode Option{if you are unable to access Safe mode .some viruses block's the safe mode}
    and more........
    software 3:similar software (file size is 22MB)
    download
    software 4:Antivicrypt
    To recover files infected by .viCrypt” extension. virus
    download
    4:Install antivirs software
    update and do full system scan
    download
    5:Go to Run type Cmd and Type SFC/SCANNOW and press enter key
    if your windows files are missing this command will restore the missing
    files from windows CD"
    make sure that you have the windows installation CD to try command
    6:Install Registry cleaner
    download
    Registry cleaner software -delete invalid entry in the registry thus speed up your system
    (please rate me)
    on Jan 12, 2010 | Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    I have CreataCard Platinum 8 version installed on my computer. Recently, I had to uninstall it and then re-install it due to some computer problems. I just tried to access the program and I keep getting...
    Hi.
    If you are unable to uninstall the software by way of 'Add or Remove Programs' or 'Programs and Features', it will be necessary for you to perform a manual uninstall by searching the hard drive for files and folders related to the program you want to uninstall. then manually removing those files and folders.
    Many programs will install files and folders in several locations on the hard drive. And, even when it is possible to uninstall software by way of 'Add or Remove Programs' or 'Programs and Features', it is always a good idea to conduct a search of the entire hard drive then manually delete any files, folders, icons and shortcuts that are found by that search because many uninstall processes do not remove all files, folders, desktop icons and Start menu shortcuts associated with the software.
    After making sure that all files, folders, icons and shortcuts have been removed from the computer, empty the Recycle Bin, restart the computer, then run a registry cleaner until no invalid registry entries are found. It is advisable to run the registry cleaner REPEATEDLY (always restart the computer before running the registry cleaner again) because fixing some invalid registry entries can cause other registry entries to become invalid.
    If you are uninstalling the program because you believe that the installation is corrupt, these steps are especially important . Making sure that all files, folders, icons and shortcuts are manually deleted and using a registry cleaner to remove all invalid registry entries is the best way to ensure that all corruptioIf you don't have a registry cleaner installed on your computer, you can download the free CCleaner by clicking on the link below
    Download Latest Version of CCleaner
    If you use CCleaner, you must remember to click on the 'Registry' button on the left side of the window before starting the scan. And, with CCleaner, running the registry cleaner repeatedly will often cause the same invalid registry entries to be displayed over and over. If that happens more than twice, the only option is to allow those invalid registry entries to remain - because indications are that those invalid registry entries are not truly
    invalid at all.
    There is also an option to try and uninstall a program using CCleaner. If you click on "Tools" option on the left hand side, click on "Uninstall" and look down that list for Creatacard and try and uninstall the software using that option.
    The 'Cleaner' option in CCleaner is a very useful tool for cleaning out unnecessary files and folders on the hard drive. So, it is also be a good idea to run the 'Cleaner' option in addition to the 'Registry' option.
    Once you are sure that all traces have been removed restart your computer and proceed to re-install the software again.
    Hope this helps.
    Regards.
    Jun 02, 2011 | Broderbund American Greetings Creatacard...
    My computer is very slow ...i think that same programs go whithout my intencion !!..please my bed inglish
    Registry Cleaner for Windows uFlysoft Registry Cleaner is freeware, the powerful combination of registry cleaner and system optimizer for Windows. Cleaning registry errors, removing junk files, running a registry defragmentation and system optimization, it can effectively speed up your PC and protect it from crashes, slowdown and errors. Make registry cleanup and system maintenance easier than ever!
    • • Totally free to scan, clean invalid registry keys and repair registry errors.
    • • One click to optimize your Windows system.
    • • Restore feature makes it more convenient and safe.
    • • Also serves as free uninstaller, sartup manager etc.
    Registry Cleaner for Windows Help You to Repair Registry Errors
    Jun 01, 2011 | Acer Aspire 5315 Notebook
    Pc slow
    Learn why is a pc running slow and how you can fix the issues from: http://www.whyismypcsoslow.net/
    Feb 11, 2011 | Acer Aspire One PC Notebook
    I have an acer one netbook /notebook---- computer freezes....worsenes w/tiime....sometimes it boots to windows then freezes,in safe mode .......still freezes....
    CorruptedSystem Files
    Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
    1. Insert the Microsoft Windows Installation CD ROM.
    2. Click Start ' Run.
    3. Type SFC/ ScanNow and press ENTER.
    4. Follow the instructions on your screen.
    Corrupted Registry
    System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
    1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
    2. Click Registry Cleaner tab.
    3. Click Start Scan.
    4. The registry scan will start. Wait till it is finished.
    5. As per the results, click Fix Now button to start repairing you registry.
    Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
    Faulty RAM
    Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
    In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
    Incomplete Installations
    Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
    Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
    Disk Space Allocated by Unnecessary Files
    Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
    Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
    1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
    2. Follow the instructions on your screen
    Dec 02, 2010 | Acer Aspire One PC Notebook
    I have a Dell with Windows 98 2nd Edition which starts up OK except it looks as if it is in safe mode when my desktop appears. While starting up, however, I get a message: Cannot find a device file that...
    Hi
    Thank you for your query
    Please can try the following
    1) Click Start>Run
    2) type in msconfig, and then click on the startup tab
    3) Remove any ticks/checks which has the mention of mcafee in there
    4) click OK and then restart
    This will hopefully take the error message away
    Regards
    shauqat
    Apr 28, 2010 | Dell Dimension XPS PC Desktop
    Unable to open hyperlinks from outlook whenever i click on hyperlinks in the mail getting nothing
    hello
    try this
    Open My Computer > Tools > Folder Options > File Types
    Check file association for:
    (NONE) URL:HyperText Transfer Protocol
    (NONE) URL:HyperText Transfer Protocol with Privacy
    Click Advanced > Highlight Open > Edit.
    application used perfor action
    under that click on browse and the oprn ie from there and do the same with
    Mar 06, 2010 | Computers & Internet
    Victim of software counterfeiting
    After installing your genuine copy of Microsoft Windows XP you are prompted with a “Your software is counterfeit” error message at startup. Even after visiting the www.microsoft.com/genuine/ site and validating, you still get the above message popping up after 2 or 3 boots. There is an easy solution to this and I would like you to follow the steps below to fix the issue.
    1. C:\Windows\Downloaded Program Files
    • Within that folder, remove any files or folders associated with .WGA
    2. Safe Mode
    • Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.
    • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…
    • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)
    • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)
      Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,
      Select the view Tab and under the Hidden Files option, select Show hidden files and folders
    3. Safe Mode Registry
    • Click on Start, Run and within the open dialog box type regedit and click OK.
    • Within the Registry Editor navigate your self to
      HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersion\Winlogon\Notify\WGALOGON
    • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)
    • After Exporting the folder, DELETE the WGALOGON folder
    • After deleting close all applications and Restart your machine back to Normal Mode
    After being prompt of a successful validation, Restart your Machine.
    Jun 01, 2009 | Microsoft Windows XP Professional for PC
    Computers & Internet Logo
    75 people viewed this question
    David Payne
    David Payne
