Question about Dell 828FI 15" CRT Monitor
Dell monitor 828fI NEEDS A FUSE ON BOARD H 250V T3 15A
I PAID FOR THIS DISPLAY THEY SAID IT WORK.I PLUG IN NOTHING I PLUG IN MONITOR THE POWER LIGH COMES ON.UNPLUG GOES OUT.OPEN IT FOUND A FUSE THIS MAYBE THE PROBLEM.ANY ONE KNOW WERE TO BUY FUSE.DELL DOES NOT SELL THEM.
Go to the hardware store.. There are a lot of it.
Posted on Feb 27, 2009
I switched it on and begins to flicker and even with noise
1)Restore Monitor to factory settings using Menu buttons.
2)Perform Monitor self test
Turn the monitor off and disconnect the video cable from the computer. Turn the monitor back on.
If self test is displayed on screen without any issues, Monitor works fine
OR
Monitor gone bad
Jan 10, 2010 | Dell 828FI 15" CRT Monitor
Dell 1800FP
change the power cable then check, if the problem persists take it to the service technician the fault may be in the power supply
Jun 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Jan 17, 2009 | Dell 828FI 15" CRT Monitor
Monitor will not show any indication of power.
4 years is a good life for a monitor, so i agree you can stick to Dell since its already proven itself... :) - As you mentioned, this monitor is not currently being sold from Dell, I would suggest an upgrade to a 19" - http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=320-5629 or a 23" one http://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-7339 ... if i were you, i would choose a 23", but for a higher pricing :)
Dec 30, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E197FP LCD Monitor won't turn on completely dead
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
Monitor Display
it sounds like you have change the postionof the screen on the monitor. try changing the horizontal and the vertical setting to remove this
May 22, 2008 | Dell 828FI 15" CRT Monitor
BenQ FP72G 17" LCD Monitor NO DISPLAY
Check the ribbon from the video card to the back of the panel. It has to be aligned perfectly and locked down in the right position at the video card side, and pushed in corrctly to the panel.
The section that contains the inverter circuit is totally seperate from the rest of the power supply. Seperated by the fuse link marked FBxxx.
Apr 22, 2008 | BenQ FP72G+ 17" LCD Monitor
Dell 828FI 15" CRT Monitor Logo
565 people viewed this question
Alun Cox
