Question about Fuji FinePix S7000 Digital Camera
"Card Not Initialized with 4GB CF memory card"
S700 can not initialized only with 4GB memory card. It is okay with 2GB CF memory card. Is there any solution?
  • 2 more comments
  • terryd1546 Oct 05, 2008
    I have same problem with the not initialized 4 gig.I have the S7000 I bought at COSTCO 2 years ago.
  • smricher12 Nov 04, 2008
    Problem: card not initialized
    Camrera- s700 fuji finepix,
    Card: olympus xd 1gb
    has worked for a year before this problem.
    Thanks for the help.
    Steve
  • YASSER 2 Jan 06, 2009
    I'VE BOUGHT A 4GB CF CARD BUT IT COMES UP CARD NOT INITIALISED AND NO MATTER WHAT I DO IT WONT INITIALISE ANY ADVICE
  • Uncle Stoat Jan 21, 2014
    Format the card as 2 2Gb partitions. The camera will only use one of them but it will work.
    Problem Solver:
  • 14 Answers
Steve, S700 and S7000 are different beasts.
S7000 is only rated for 1Gb compact flash cards. It apparently works with 2Gb ones but as I and a lot of others have discovered no matter how you tweak around sectors and clusters it won't read the thing.
This is a Fat16 limitation.
Posted on Mar 01, 2010
    President:
  • 423 Answers
The 4gb cards are a newer type of SD card called SDHC (Secure Digital High Capacity). Most of the S700 production was before SDHC cards hit the market. Later production S700's had been internally tweaked to accept the SDHC cards. 2gb is the largest you can go on your S700's, but beware, some of the 2gb cards are SDHC also, now.
Posted on Oct 07, 2008
I just bought a brand new scandisk 4gb card and it says that the memory is full even though i didn't take any pictures... what do i do?
The S700 uses SD cards. Your new 4GB card is actually an SDHC card. While it will fit into the slot, it will not work in the S700 (as you've discovered). You'll have to limit yourself to SD cards, 2GB and smaller.
Jun 22, 2010 | Samsung Digimax S700 Digital Camera
Fujifilm finepix s5100 card not initialized
Have you tried to format the card in the camera not the computer it has to have the camera files on the card the camera will put the files it needs on the card.
Oct 03, 2009 | Fuji FinePix S700 Digital Camera
Fuji s602z CF II card not initializing
I've bought a SanDisk ExtremeIII 4GB CFI card. Ofcourse, at the beginig nothing worked. Camera format command worked neither (initializing problem,...). I then formated my card through a car reader on fat16 and now everything works. Just make this command: format <volume>: /FS:FAT. After checking and formathing the card, you will be asked to go on by 64K size of cluster. say Yes.
Jul 31, 2009 | Fuji Finepix Z20fd Digital Camera
My S7000 has the message "card not initialized"
The S7000 cannot handle cards larger than 2GB.
If you need 4GB you can also fit a 2GB type 2 compact flash card which is the american standard.
For europe you will get a type 1 card this will also fit it is just slightly thinner.
Jun 19, 2009 | Fuji FinePix S7000 Digital Camera
Finepix s7000 new 4gb card not initialized fujifilm cf
The S700 as it came from the factory CANNOT use a 4 gig card. You must go to the Fuji USA website and download the firmware update. You will need to have the program that came with the camera installed, and the cable that also came with the camera. Make sure that you have fresh batteries in the camera. Instructions are on the Fuji website along with the download for the firmware. You are actually going to "flash" the firmware in the camera just as if you were doing a BIOS flash in your computer. Personally, I only use smaller cards and remove the pics soon after I take them. A 2 gig card will hold about 150 full rez pics. Get them out of the camera....don't save them forever on the card!
Jun 12, 2009 | Fuji FinePix S7000 Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
My FujiPix S700 is flashing card not initialized
If you have a new xD-Picture card that says "card not initialized" go to set-up and when it says "format OK? Erase All Data" press the triangle on the left of the menu/ok circle so it goes to "OK" then it will change to an hour glass going up and down until it stops and MAGIC! the card is initialized, at least it worked for this time for me.
May 14, 2009 | Fuji FinePix S700 Digital Camera
Fujifilm s9600 cf memory card is not initialized wot can i do
If possible you can copy the directory with you pictures and clear it out the format the card and copy back the empty directory. I hope this works I need the directory for my card if it works post it..........
Jan 13, 2009 | Fuji Finepix S9600 Digital Camera
Can't initialize SanDisk Ultra II for S7000
try formatting it in the computer, then initializing it in the camera.
It's possible that the camera can only handle memory up to 1Gb. Try a 1g CF card.
Jan 01, 2009 | Sony Alpha DSLR-A200K Digital Camera
Memory card
Because this camera only understads FAT16 formatting, it does not accept any card larger than 2GB so your best bet is to use the current crop of standard 2GB CF cards, most newer ones (usually 16X and faster) are alsa fast enough for continuous VGA video as well. The best brands IMO are Lexar and Sandisk, but avoid the WA enabled cards, this camera can't make use of WA, it just slows the througput down.
Alternatively you may partition your 8GB card to a 2GB partition, but the rest of the card won't be accessible.
Aug 28, 2008 | Fuji FinePix S602 Zoom Digital Camera
Fuji FinePix S7000 Digital Camera Logo
906 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
