Question about PreSonus 6x10 Firewire Recording Interf Sound Card
Skips and clicks
When I am recording my instrument track, I get skips and stutters. I've tried everything. I have windows vista 2.4 and sonar
Still having this problem? Mine was doing the same thing, so I went on the Presonus website and updated to the latest drivers. Mine hasn't done it since. If you have done that as well and it is still doing it, then I fear my problem may come back too. Hope not.
Jeff
Posted on Oct 29, 2008
I am going insane trying to figure out why my vocals are recording so inconsistently - volume all over the place. It isn't obvious until I take the wave file to my engineer who's recording my CD. ...
hmm, it could be something simple such as a faulty cable from mic to pc, it could be a faulty input if you are using a mixer, could be a faulty mic, it could even be a piece of software running in the background that is conflicting with sonar and causing this problem. This should be an easy problem for your "engineer" to sort out. as seeing it makes it 100 times easier to fault find. Thats part of being an engineer!
Sep 03, 2011 | Edirol UA-25 External Sound System
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
Computer stops responding or sound just stops on Sonar 7 with Vista. Confused whether to set Sonar to use ASIO driver or MME or the other one I can't think of now. Dan
Hi
The most compatible driver would be the one detected by Vista in Windows Update. Give that a try and see if it can find a hardware device driver for the Sonar. Ensure the Sonar is connected and on before you check for updates (Start > All Programs > Windows/Microsoft Update).
Oct 11, 2009 | Tascam US-144 Sound Card
Clicking noise when recording bass directly into 1641 to Sonar studio 7Running ASIO 4all drivers Vista with quad 1.8's, 3 Gigs ram
Is it just clicking noise or is it skipping. check out and tell me
one more thing , can u specify what mother board you are using.
Contact me immediately
greatvedas@gmail.com
Aug 02, 2009 | Tascam US-1641 Sound Card
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Stuttering sound when recording
It's crucial that you understand the concept of latency.
Latency it the time delay between the trigger and the operation.
In terms of computer sound recording and generation:
1) The time between the midi trigger and the sound generated by a software synth to come out of the speakers.
2) The time between the analog audio signal input to be converted to digital and stored on the hard drive.
3) The time between the digital audio track to be retrieved from the hard drive and converted to an analog signal that comes out the speakers or headphones.
4) All of the above at the same time.
The factors that contribute to this latency form a pipeline that include the A/D (analog to digital) device (UA-25), the software drivers for that device, the operating system, the recording application being used, the operating system again, your internal computer speed and your hard drive speed. Remember that the sound needs to go both in and out, often simultaneously (thats called full duplex).
A latency of up to 50ms is probably tolerable, but for optimum recording, it should be closer to 5ms. If you were to go over 50ms, you would need some sort of time compensation, whether automatic or manual, because nothing would synchronize properly, be it the metronome or previously recorded tracks.
"What's this mean, and how does it relate to my situation?" you ask.
Lemme tell you. The recording program and drivers will incorporate software buffers to adjust for slower components in your sound recording pipeline. Without buffers, or with too few buffers, the pipeline can drop information (sound) if it is not be able to process it quickly enough. This will often result in stuttering and skips. Sound familiar?
So why not just put LOADs and LOADs of buffers in the pipeline? You most certainly can, but for every buffer you add, you gain a bit of latency. And remember that too much latency is a bad thing.
"Ouch! I still don't get it. What am I supposed to do?" you ask.
I reply, "Good question, Grasshopper." You want to stop your stuttering. You need to increase the efficiency of your sound pipeline. For regular people this means the following, in order:
  1. Make sure you purchase an A/D-D/A device that has low-latency drivers utilizing one or more of the following standards: ASIO, WDM, MME or CoreAudio. Selecting the one that your RECORDING APPLICATION utilizes. ASIO is widely supported and good. WDM is the worst because it is really just regular Windows drivers, but they can sometimes be optimized for low latency.
  2. Make sure you install your drivers properly, selecting the one that your RECORDING PROGRAM uses.
  3. Make sure that your recording application has the hardware selected for your A/D-D/A device and the drivers that you previously installed.
  4. Make sure that your recording application is using ONLY the hardware specifically designed for low latency, which is your A/D device that you previously purchased and installed.
  5. Make sure you include as many buffers as you can while maintaining a low latency. Often, this is dependent on your recording application.
  6. Set the UA-25 to 44.1KHz or 48KHz, not 96KHz. 96Khz does not allow for full duplex.
Do these things and attempt to record something. If it stutters right away or you get "underruns" you need to increase your buffers. If everything is peachy for a while, but soon you start getting skips, try increasing the buffers, or get a faster hard drive or turn off some digital effects.
In summation: A Celeron 1.6GHz should have sufficient power to record, play and add a few VST plug-ins, maybe even a dozen or more. Chances are that your hard drive is fast enough to retrieve and record 16-32 tracks at a time. Turn off all the stupid, little programs that make icons near your clock, like the DELL support and Weatherbug and AIM and AOL and HP Monitor and anything that takes processing power and hogs memory.
Jun 29, 2008 | Edirol UA-25 External Sound System
Recording live d.j. mixes ,
Audacity and Krystal (free windows based programs)
What about an LE version of Cubase or Sonar (little hard to learn if your just want to record something light and not edit).
May 28, 2008 | M-Audio Fast Track Pro External Sound...
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Canecting US122 with Sonar HS4
Hey there,
Try the latest US-122 driver (3.4.0), you can get it here:
http://www.pcmusic.org/software/version.php/lang/en/id/10422/
There might be a latency problem with the Asio4all driver too, try the US-122 16bit or 24bit driver, they are actually Asio drivers.
Also navigate to Windows Control Panel and make sure that a Windows Media Player Update hasn't minimised the Wave Control Sound.
Good Luck and have fun
Chris (ziraffa)
Mar 02, 2008 | Tascam US-122 USB Audio/MIDI Interface...
SONAR LE NO AUDIO
Microsoft re-engineered the audio bus for Windows. HD Audio is hardware specific, in the sense that specific drivers have to be written to make a piece of hardware compatible with it. Roland is not writing a driver for the UA 25 because they want you to buy an UA 25EX. Get my drift? The UA 25 uses Kernel Streaming, the old way, which exists in parallel, sort of, with the HD Audio bus. But the new ways are always prioritized over the old ways in software, so there is bus contention (glitching).
To fix this there are a few things you can try:
1) Roll back to SP2. SP3 implements the HD Audio bus, so don't use that implementation. If your laptop has an HD audio sound card then I doubt it would work, but your UA 25 would.
2) Try ASIO 4 ALL. This fixed everything but glitching in VST instruments.
3) Reduce the amount of stuff your computer is doing. Optimize your OS by turning off the cute shaded windows and desktops and various processes that you don't need to see or use. There are sites for this. This increases available RAM, CPU time, etc.
4) Video hardware acceleration, sometimes, would fix bugs in software left in by not so clever programmers.
4) You can always just give-up and go along with the bastards and buy new stuff and toss the old stuff.
-SQA MGR
Sep 04, 2007 | Edirol UA-25 External Sound System
PreSonus 6x10 Firewire Recording Interf Sound Card Logo
113 people viewed this question
Top PreSonus Computers & Internet Experts
Matthew Spark
Matthew Spark
Brian Sullivan
Brian Sullivan
Tom Chichester
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
