Question about LG WM2487H Front Load Washer
Clear greasy stains appearing on clothes from brand new LG front loading washer
My new LG Model WM2487HWMA front loading washer puts a clear grease-like stain on some of the clothes in each load. The stains appear in splotches and seem to show up more on darker colored cottons. I do not use fabric softener, and have cut way back on the amount of Tide HE I use (less than what the Tide reco's). I do a lot of laundry and may have used too much detergent when I first got the machine 3 months ago, but now I've cut back and the spots keep happening. They are sometimes hard to get out, but usually go away with Oxy Clean and re-washing. It has ruined some of my clothes already. Please help!
  • yvonnewilson Dec 30, 2008
    I've got the exact same problem, clear greasy splotches sowing up randomly on dark coloured clothes from my new LG front loader.
  • Anonymous Jan 12, 2009
    I have the exact same problem. I have cut back on laundry detergent (I too use Tide HE) and I do not use fabric softener. It only seems to show up on dark, mostly cotton clothes. Please help!
  • 958 Answers
The grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Grease like stains on clothing after washing
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
Jul 30, 2013 | LG WM2301HW Front Load Washer
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
My wm2487hwma lg washer wont come on, drum light is on, but everthing else is out , no power. Unplugged washer and reset at fuse box, power came on, but same problem occurred.
I have an LG washer slightly different model but had the same problem. It washed the clothes but then the light would stay on but the washer would not turn back on. Remove door switch unplug wire that conects and check the connections. which requiered taking off the top and front of the washer. Mine were corroded after only 2 years. We cleaned the connection and it seems to be working fine again.
Sep 10, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Sep 16, 2009 | LG WM-2032H Front Load Washer
Washer is leaving grease all over my clothes
I have this problem on my front loading washer too, but only when washing white clothes. I have just read that perhaps the inlet hose is disintegrating from the hot water being too hot. The hose disintergration can cause black greasy stains on the clothes. I am going to check out the inlet hose when I get home. Hopefully this is the problem... I am sure a new inlet hose is a lot cheaper than a new transmission or new bearings. BTW, my washer in only 18 months old.
May 18, 2009 | Washing Machines
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LG WM2487H Front Load Washer Logo
1,347 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
