I think it's because the stupid Intel PRO/Wireless 2200BG 802.11g/b continues to startup and at the same time stop the windows service. This has the effect of making the wireless networks invisible, with the message "Windows cannot configure this network..." I can't seem to find a place to turn off the Intel software, even though I've uninstalled all Intel programs. help!
-   i put a check in the box to use windows to configure my wireless settings and the checked box saves and the check goes back to normal and its stopped the next time i reboot, do i have to put it back in everytime i log in. -   Guest
Feb 02, 2009
-   my dad has a sony viao and i tend to fix all his computer problems recently the laptop completely broke and had to get taken to get repaired since its returned it wont connect to our wirless network same thing keeps happening in the "view available wireless connections" window it says basically another program is being used to set up wireless service and ive gone to start>run>services.msc and started the WZC but it stops again after a few seconds, cant find a way around this problem :(-   mcbrad09
Open Control Panel
Right click on Wireless Network Connections and select properties
The Properties window should open, click on the Wireless Networks tab
Put a check in the box for "Use Windows to configure my wireless network settings"
Click Ok
This problem is a frequent problem. There are several solutions that can be done. I would recommend going into wireless network connections, right clicking on it and select repair. This can sometimes fix it. You can also try changing the compatibility mode with which it runs in. Sometimes you can go to the intel website and get an older version of the software, and keep trying them until they fit. It seems you have to keep trying things till it works.
hi!! I use the intel proset wireless for my laptop ...I get the message "error loading...
(More)
hi!! I use the intel proset wireless for my laptop ...I get the message "error loading plug-ins..application will exit" everytime and so it doesnt connect to wifi....I've tried reinstalling the software but no use....please help me get my problem fixed
Laptop wireless has stopped receiving signal all of a sudden. The switch for wireless is on. It just...
(More)
Laptop wireless has stopped receiving signal all of a sudden. The switch for wireless is on. It just stopped picking up the signal. I tested to see if the driver needed installing but it is up-to-date. Ive tried reseting router, re-entering wap/wep key. Disabling the driver/enabling. However, if i sit right next to the router it picks up a connection, but although it says excellent it is much slower than what it usually was. As soon as i change room, its lost again. The router has not been moved/played with. Sitting in same spot as ever. thanks
My laptop dell 600m cann't found the wireless driver any body have answer how we can reconize our...
(More)
My laptop dell 600m cann't found the wireless driver any body have answer how we can reconize our wireless pro ??
i removed intel pro/wireless 2200 bg network card from acer to my toshiba satellite p20 it work all...
(More)
i removed intel pro/wireless 2200 bg network card from acer to my toshiba satellite p20 it work all right but can not receive any network can u help me out
