After a power loss, I turned on unit. Unit displayed "HELLO" for about 30-45 sec then displayed "F99" then turned itself off. As per manual, I reset the unit by pressing the power button for 3 sec. The same display msgs appeared. As per the manual, I pressed the power and open/close buttons simultaneously to cause a factory reset with the same result. What now?
SOURCE: I bought DMP-BD80 blu ray player.
make sure the line is good
if so the machine has a faulty network connection
which happens from time to time
SOURCE: DMR-ES35V shows u99 error, have
Hello, I found a receipt for my VHS and it is still under warranty until the end of december 08.
It is now in the electronic workshop being repaired.
Thanks for your follow up
Gary
SOURCE: How can I unlock my panasonic dmp-bd80 blu ray
To return to the factory preset
(No setting)
≥Reset the unit as follows:
1 Press [POWER í/I] on the unit to turn off the unit.
2 Press and hold [;], [POWER í/I] and [< OPEN/CLOSE] on the unit at the
same time for more than 5 seconds until “HELLO” is displayed on the unit.
3 The power will turn on and then turn off.
SOURCE: playing the soloist on panasonic dmp-bd80. get
Try updating the units Firmware:
Firmware is software that exists usually on chip or flash memory within a larger piece of hardware, such as a Blu-ray player. Firmware can be upgraded to fix a technical problem with the player or to meet new industry standards.Firmware updates can be applied either by downloading them directly to your device, or by disc installation.
SOURCE: Unlock Region On My Panasonic
The only way you can do that in this player is with hardware modifications. You will need this
http://www.gattiweb.com/bluraymod.html
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
