Question about Mitsubishi Televison & Video
Projection mirrors need cleaned - Mitsubishi Televison & Video
  • 927 Answers
Good Day;
Cleaning mirrors, there is two ways to do this remove front or approach from back. Just use soft cloth and cleaner.
Good Luck, big IRISH.
Posted on Sep 28, 2008
Hitachi projection tv mirror problems
the mirror in projection tv, needs to be cleaned along with the lenses for each crt clean them both and your tv will look like new good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
MIRRORS NEED CLEANING
Remove the cover around the front screen...this is the best way to get to the mirror. You may need a service manual if you can't figure it out how to get it off...but in most cases the trim will snap off.
Jun 09, 2012 | Philips Magnavox 51MP392H Rear Projection...
I have a hitachi 55vf820 lcd rear projection tv. How do you get the cover off to clean mirror?
Don't try that as the mirror almost never needs cleaning and MUST be cleaned with a special cleaner---leave a single fingerprint on that mirror (or a smudge) and it will stand out in the picture like a sore thumb.
Reason to clean mirror?
Apr 09, 2012 | Televison & Video
Do I need to clean the screen on a DLP television? I have only changed the bulb. I feel like the picture is getting less sharp.
Not the screen so much as the projection mirror which is located on the rear wall of the Set. If the mirror gets dull it can make the picture dim and dull looking. Cleaning the mirror will help. Some models have a small mirror which projects the image back onto the rear mirror. Dont use windex, just a damp cloth then dry good.
Jul 21, 2011 | LG Televison & Video
How do i clean the bulbs and mirrows in a hitchi 42v710
The bulb is not an imaging element meaning dust on the bulb will not effect image quality and thus recommend not messing with it. You will need to remove the covers and use a very soft cloth to clean mirror. These products us a "first" surface mirror and scratch or imperfection or cleaning swirl on the mirror will show up on projected image. Suggest his be left to a professional. good luck
Jul 05, 2009 | Hitachi 42V710 42" Rear Projection HDTV
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
Cleaning rear projection screen tv
It is very rare to have to clean the mirror. It us upside down so it does not collect dust. It does however collect nicotine if there is a smoker in the house. Some RCA mirrors are not glass and should not be touched. The lenses do get dusty and should be cleaned.
Mar 01, 2009 | RCA P52926 52" Rear Projection Television
How to locate and clean the mirror on philips projection set
Remove upper back. The mirror is right there facing down at 45 degree angle to the three projector lenses and the screen. It is a silver polyester film laid over a backing board. I cleaned mine successfully with very soft paper towel (Bounty) and 70% alcohol. Rub gently in small circles until the alcohol is dry. If you just wipe the alcohol across the surface it will dry with a bad white haze. You have to rub it dry and then keep moving on until whole mirror is cleaned. This is only necessary if there are smokers in the house. Cleaning gets the nicotine film off the mirror. Best to not clean if possible.
Jan 26, 2009 | Philips 55PW9363 55" Rear Projection...
Cleaning mirror
Hello mrdish,
the mirror is in the attached to the top rear panel, remove the top rear panel to clean the mirror.
I hope this helps,
Thank you,
Shuttle83
May 22, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Mar 31, 2008 | Televison & Video
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
463 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
