Question about Dishwashers
Dishwasher won't clean properly anymore.
The unit started making a new & different noise that sounded like water squirting inside. Since this began to happen, it won't clean properly & leaves food residue on dishes & in cups. It still makes that "different than usual" noise. This has been happening for about 2 weeks now. When the cycle is finished all the soap has been used like normal & changing brands of dishwasher detergent has no effect on the problem. It's a Maytag mdb3100awx.Thanks!
Sounds like the hose is clogged... i used to fix these.
first check to make sure the drain inside of the dishwasher (located on the bottom usually towards the back) does not have food clogging the drain. if there is nothing there than its more than likely a hose underneath the dishwasher. make sure you turn the water off before trying to fix this.
Posted on Sep 28, 2008
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
LG dishwasher LDF8072ST won't finish cycle.
It sounds like the detergent open solonoid is not activating, which could be the controls or just a bad solonoid. If it is under warranty just let the repair man know what is happening and let him do his thing and laugh as the manufacture pays the bills Had a guy in six times on my dishwasher until it was out of warranty now I just fix it myself.
Sep 06, 2012 | LG LDF8072ST FulIntegrated Steam...
Running but not cleaning
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Loud noise
Very loud squeaking sound, at the start of each cycle.
Jan 09, 2008 | Kenmore 16639 Built-in Dishwasher
Strange noise from my Bosch Dishwasher SHU66C02UC/14
It just the pump noise. Since your dishwasher works properly you can ignore this noise.
Sep 09, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
295 people viewed this question
Top Dishwashers Experts
