Page numbers Cannot get page numbers to appear on pages.
  • 1 more comment
  • Harold Pauly Sep 29, 2008
    I am running Quarkexpress 8.0, and am trying to display page numbers automatically on the pages of my document.
    There used to be a keyboard shortcut for this function, but I cannot find.
    Any help would be appreciated.
  • Linda Goldsmith
    Linda Goldsmith May 11, 2010
    what program are you using
    most programs will set page #'s in the printsetup feature
    go to file/printsetup/you will see page numbering
  • Baja Data / Jay Arias-Chavez
    What software are you asking about?
  • 122 Answers
Create the page #'s in the header/footer option usually in view/header/footer
make sure that the gutter is large enough to see the #'s
go to print preview to check this
Posted on May 04, 2009
I am trying to start my page numbers on 10 instead of 1
  1. Double-click anywhere on the header or footer to unlock the Design tab in the top menu.
  2. Click the Page Number command. In the menu that appears, select Format Page Numbers
  3. A dialog box will appear. Click the Start at: button. By default, it will start at 1. If desired, you can change the number.
  4. Click OK.
Good Luck :)
Feb 26, 2014 | Microsoft OFFICE 2013 HOME AND BUSINESS 1...
How do insert page numbers on page maker automatically?
To have Adobe® PageMaker® automatically number your pages, if the template isn't used, place a page number marker on the Master page of the document.
  • Go to the Master Pages by clicking on the page icons with the L and R on them at the bottom left corner of the screen.
  • Using the Text tool, draw a text block in the general area for the page numbers.
  • On the Mac, press Command+Option+P or in Windows, Ctrl+Alt+P.
  • Depending on the page you are on, the page marker will show up in the text block, LM on the left page, RM on the right page.
Auto page Number
  • This text can be formatted like any other text on your pages.
  • Select the Pointer tool and move the copy block into the correct position.
  • Click on a page icon to go to a page in your file and the actual page number will appear.
  • If the page icons do not have the correct page numbers on them, go to the File menu, select Document Setup and change the Starting page # field to the correct starting page number.
Another solution
Adding Page Numbers in PageMaker 7 Page numbers add shine and organization to any publication. In Adobe PageMaker 7, page numbers are quite simple to include, but function is difficult to find first time. After activated, page numbers show throughout selected project.
Step 1
Start project in PageMaker 7.
Step 2
Choose text function from toolbox. It appears as T.
Step 3
Click L/R function. It is placed under ruler.
Step 4
Click master page where page numbers placed and push "Ctrl+Alt+P." Page number must show.
Jun 09, 2011 | Adobe PageMaker 7.0 Classroom in a Book...
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
I have a Samsung SCX-5635 multi-function printer/copier/fax & scanner. It worked great with my old IBM desktop computer running XP. However, a few days ago I upgraded to a new HP custom built HP...
Are you sure the driver is set to A4 paper and not Letter Size. Letter size is the default. Letter size being larger than A4 would mean the print would be off the bottom so you wont see it. Could be as simple as that.
Apr 23, 2011 | Samsung SCX-5635FN All-In-One Laser...
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Pdf file wont keeps saying no pages selected and always asks me to save it
Open Your PDF File
Press Ctrl+P
It appears To You This Page :
1- Select All The Pages
2- Number Of pages
3- Press Ok o Print
Jul 08, 2010 | Microsoft Computers & Internet
How to add a border in microsoft word office 2003
To add a border on a page, try the following:
  1. On the Format menu, click Borders and Shading, and then click the Page Border tab.
  2. To specify an artistic border, such as trees, select an option in the Art box.
  3. Click one of the border options under Settings. To specify that the border appears on a particular side of a page, such as only at the top, click Custom under Setting. Under Preview, click where you want the border to appear.
  4. To specify a particular page or section (section: A portion of a document in which you set certain page formatting options. You create a new section when you want to change such properties as line numbering, number of columns, or headers and footers.) for the border to appear in, click the option you want under Apply to.
  5. To specify the exact position of the border on the page, click Options, and then select the options you want.
If you'd like to add a border to a picture, text or webframe, just click on this link for further instructions:
Mar 31, 2010 | Microsoft Computers & Internet
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Not all of page number shown when printing in Excel.
Hi, this is a configuration problem, the printer crops anything trying to be printed near the end of the page. Increase the margins or put the page numbers up in the page.
It happens in MSWord too cutting in the middle the page numbers-
Feb 04, 2008 | HP PSC 1510 All-In-One InkJet Printer
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
