Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Front Door Amana Computer Door Pad Changes on its Own? Amana ARS2667BW
Hi - I have an Amana ars2667bw refrigerator. The front door has a touchpad where you can select ice, crushed ice and water. A few days ago - I was awoken in the night by the computer repeatedly saying 'cubed ice' - it would not stop, so I put it on silence. I now have the fron door in 'lock' status because if we use it, all 3 front buttons flash and change intermittantly and I have to unplug the fridge to be able to get to the 'menu' button to lock it from doing this. Also - if you push - say the water button, it will deliver water - but will switch by itelf all around the keypad and will dsipense whatever it changes to. Is there a short in the compter system? Is this repairable? I do want to mention that we had a crazy power/on/out surges a week ago during the IKE storm - so did this cause the problem?
  • 958 Answers
It could be the power outage. electronics are very sensitive, it could be damage by just static electricity alone. i suggest that you can plug it to an automatic voltage regulator with a time delay so that it could save your unit after a power interruption.
regarding your problem now, it could just be a touch pad problem. maybe that is the only part fried by the surges. i assume the refrigerator cooling performance was not affected. only the touchpad panel is affected.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Amana refrigerator # AFD2535DES
needs cleaned..underneith..use your vacuum..take off kick plate.in front..go to Amana website they have answer section...
Aug 28, 2009 | Amana AFD2535DES French Door Refrigerator
Water filter
some amana designs are different. filter can be underneath freezer door at bottom front or some are inside refrigerator compartment at top right.
Jun 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Control pad not working. Some lights are lit but
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Get me the make and model number so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer door hard to close
Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
Mar 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana Model ARS2667BW
sounds like the compressor or compressor relay. i would call a technician for this one.
Sep 13, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana Refrigerator Problem
ther should be a small allen screw holding them on no?? if not grabbig the handle and lifting straightup will undo front the clips and ssnap them back on when in. I thihk id rather remove the dorr assy though, (3) 5/16 screws under the top hinge covers, adn by pullinf outh the freezer door youll see 2 phillips head screws bout 5 inches in on either side from the rfornt panel of door located in the sliding track itself, after reemoving the screw the entire door will lift off and out, you gain another 3-5 inches that way and not worry about scratchin the appiance going through doorway
Apr 04, 2008 | Amana AFD2535DES French Door Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
219 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
