Usually this happens after installing Itunes. Try this for the fix:
Fix for missing DVD/CD drives.
Create a text file with
NOTEPAD containing the following data exactly as below and name it FIXCD.REG
You should have 3 boxes on the bottom in NOTEPAD.
1)Filename : fixcd.reg
2)Save as type: all files
3)Encoding: ANSI
If you do not change it from txt type to All files type, then the file
will actually be fixcd.reg.txt, this won't accomplish the desired result
Double click on the file and say yes to the merge into registry question.
----------------------- Use text after this line, contents of FIXCD.REG -----------------------------
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"UpperFilters"=-
"LowerFilters"=-
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdr4_2K]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdralw2k]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdudf]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UdfReadr]
------------------------------ Use text before this line --------------------------------
