Many thanks for response however I cannot find which one it is in the manual, the manual does not advise times at allMany thanks for response however
You can't post conmments that contain an email address.
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it
run for a minute or two, then stop the cycle, open the lid and slowly
add the gallon of hot tap water. Don't overfill — you just want to
raise the water level so that it is able to reach and clean the inside
top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle.
In a couple of minutes, stop it again and just let it sit for at least
30 minutes. Afterward, let the cycle finish, and open the lid to air
out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4 and here: http://deseretnews.com/dn/view/0,1249,600124768,00.html
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... )
You answer will allow us to direct you the solution.
Good luck !
