Question about LG WM-2077C Front Load Washer
Washing machine drum won't turn under power
My LG washing machine, model wm2077cw, drum rotates freely when off and when not in a power situation but will not rotate under power. I have checked the wires to the motor sensor and all seem to be secure. What is my next move.
  • wood yonge Aug 22, 2013
    first check stator and hall sensor, if are ok, replace main pcb
  • 958 Answers
Is the washing machine went to its usual cycle? put water in?
if you think the motor should have run already, then it could be the motor or the motor inverter.
check the motor leads for equal resistance, if i'm right, you may have a three phase motro so the three leads that comes out should have equal resistance.
also, if you can monitor the voltage present in the motor leads while it is plug in and you are waiting for the motor to run, if there is voltage then there is a problem with the motor, if there is no voltage present, then the inverter unit would be the defective part.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
My LG washing machine, Model# WM2077CW squeals a bit as the spinning comes to a stop. All other operations are fine. Is this model belt driven or am I looking at some other issue? Thanks.
direct drive. two other issues come to mind. one, your front door seal is malformed and touch drum someplace. two, your bearings and bearing seals are making the noise and starting to wear.
Oct 11, 2015 | LG Washing Machines
LG WM3431hs drum won't turn on dry cycle
Broken drive belt tho your model number is not for a dryer.
Feb 04, 2018 | LG WM3431 Front Load Washer / Dryer
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
I have a model WM2077CW LG washer. The LE error
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 22, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Lg wahing machine WM2077CW a little bit of water enters cycle slowly, and i don't see soap nor water
Hi, Turn the faucets off at the wall and remove the inlet hoses. Look inside the inlet valve and see if the screens inside the valve are plugged.
I hope this helps
Vic
May 30, 2009 | Washing Machines
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Lg front load washer model wm2077cw
Your board has an built in fuse that cannot be replaced.  You will need to have the control board changed.
Sep 24, 2008 | LG WM2077CW Laundry XL Front Load...
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
LG WM-2077C Front Load Washer Logo
356 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
