Question about Motorola Mobility L6 Cellular Phone
Motorola l6 not charging .
Both batt and charger were tested
I dont have motorola L6 software cd . is it available on internett at free of cost
Posted on Sep 30, 2008
Mabye their is something wrong with the part you plug the charger in
Posted on Sep 28, 2008
3 Suggested Answers
SOURCE: Motorola L6 Phone not charging or working
posted by oscar45 Sept 28,2008
This phone does not and won't turn on, charger and batt were tested
posted by oscar dy on Sept 28,2008
derryver
  • 5 Answers
Well,
I solved the problem for my L6. IT appears that somehow the phone is software dependent. Meaning that you need to have the Motorola Software for the phone installed in your computer, connect the phone and voila! At least it solved my problem. All of a sudden it charged automatically and I can now charge with the power adapters too. (Yes I too went and bought a different charger, then when it didn;t worked I got a different battery..etc.) just give it a try. I think you can get it for free online somehow, just google it.
Starter spins but won't engage flywheel
Bench test with batt charger or batt 12.6 volts indicates good batt take positive cable from charger or jumper cables and touch it to the copper stud where u would with red cable in vehicle and then ground or black cable to side of said starter watch for the Bendix or small gear to pop out if motor just spins then tap pos cable to solinoid terminal. usually marked S or I it should activate Bendix if not replace solenoid or have it tested at local parts supply.
Mar 06, 2015 | Garden
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
Oct 24, 2013 | Health & Beauty
Batt. not ataying charged
Check output of battery when bike is idling.
If still 11 volt, then your charger, which is the magneto is faulty or the wire is broken from it to your battery. If the charge varies when you test when engine dead to engine idling, wire is fine. Should be 13 to 13.5 volt when idling if magneto is ok.
J
Jun 09, 2010 | 2005 Suzuki Boulevard C90
I plugged in the charger and after an hour the blinking power button stopped blinking and the camera now does not turn on? M1093 IS camera
If the cam. was plugged into the cam and on. Then it doesn't charge it only transferres pics.
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak EasyShare M1093 IS Digital Camera
Lens popped out and won't charge
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth and reinsert
Pls test with an alt. batt./ charger
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new charger.
Contact KODAK:
Oct 27, 2009 | Kodak EasyShare V1003 Digital Camera
Lens wont retract
Remove the memory card and the battery
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If it will work normally in this mode it is most certainly the batt. Your batt is covered by the man 1 year warranty
Contact KODAK:
Jul 13, 2009 | Kodak EasyShare V1003 Digital Camera
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
No power, all buttons flash when connected to ac charger
if charger voltage is ok then it could be phones charging controler is not working. if phonebook is only thing you need could recharge battery directly from your charger and then save your phone book. cut off charging plug-connector from your charger make two bare wires and then apply red wire to battery "+" and blck to "-". 5min of charging will be enough to copy your data
Jul 21, 2008 | Samsung SGH-c225
Motorola Mobility L6 Cellular Phone Logo
102 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
