Question about Toshiba Satellite M35X-S349 Notebook
Satellite laptop turn off
Hi I have a satellite m35x-s349 , some time this laptop turn off in any moments and I need turn on again. I hoppe somebody can tell mr some tips about it.
Thank you.
Maurice.
  • 4,889 Answers
Hello maurice. Looks like you have an over-heating problem. The CPU has more chance of overheating when you use graphic intensive applications like Games etc., Clogged heatsink is one of the reasons for over heating. It would require you to get to the heatsink and clean any dust or any other stuff that may have got clogged in the heatsink. Another Idea will be to buy some kind of laptop cooler like the one below.
http://www.circuitcity.com/ccd/productDetail.do?oid=89840&om_keycode=3
Posted on Sep 28, 2008
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Somebody hit my laptop with something and now the screen won't turn on. The dvd drive opens and the lights come on so it seems to be working other than the screen. Its a toshiba l305-s5926. Any ideas?
if it will run an external screen then get it running and back it up first.
then once your data is safe you open it up and look for a loose connector or some other broken part.
Hope this helps
Thanks for using FixYa
Aug 12, 2010 | Toshiba Satellite M35X-S349 Notebook
Toshiba satellite m35x-s114 ( black screen ) , i can hear the fan on start up. is there something i can try to solve the problem.
you need to pull the top of the unit off and unplug the monitor from the main mother bord then plug it back in to re fire it .
Jul 04, 2010 | Toshiba Satellite M35X-S349 Notebook
Satellite M35X-S349 PC Notebook: How do I speed up my toshiba pg 35 laptop...
RegTOOL can helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/
May 18, 2010 | Toshiba Satellite M35X-S349 Notebook
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
Boot Recovery Wizard
try f1 f2 if that dont work then f10 f11 or f12 it has to be 1 of them
Oct 07, 2009 | Toshiba Satellite M35X-S349 Notebook
Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Aug 02, 2009 | Toshiba Satellite M35X-S349 Notebook
Need to replace toshiba satellite m35x-s163 fan
Unless you are really comfortable with opening laptops to upgrade parts, I won't recommend doing this. Rather get a notebook cooler. It does the job of cooling the notebook pretty well.
Nov 05, 2008 | Toshiba Satellite M35X-S349 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
