Question about Lexmark Office Equipment & Supplies
My Lexmark all-in-one model X4690 printer won't print the bottom border on a page. Is this an alignment problem? How do I fix this problem? Thanx
  • 2 more comments
  • clsanc Sep 28, 2008
    I've never used the scanner feature (I'm a newbie)but the copy feature works ok
    Thanx, Ekse, I'll give it a try but I'm really, really sceered!
    Ekse, It's me again re:Lexmark x4690 not printing bottom page border. I forgot to tell you that when I try to print I get a pop-up box that sez my borders are outside the printable area. I print anyway and that's when the bottom border fails to print. I've tried changing margins and setting in the Page Borders dialog box. Does this change your diagnosis and prescription?
  • clsanc Sep 29, 2008
    Thanx again,Ekse. I'll try reseting the defaults. I really appreciate your help and will recommend this site to my newbie friends
  • Lexmark Master
  • 6,487 Answers
This can be resolve by updating the printer driver and also you can try first to uninstall and reinstall everything and after that try to do a test print so we can check if it will print fine with a test print so we'll know if this is alignment prolem....
Hope that helps.............
Posted on Sep 28, 2008
  • Lexmark Master
  • 13,433 Answers
Its possibly a driver problem, try uninstalling the printer and then installing it again. It should correct any communication problems, you need to also unplug the printer after you have uninstalled it.
if you scan directly on the printer, does it print correctly?
  • Ekse Sep 28, 2008
    ok, so clearly its a issue with the computer and the printer, most likely the driver / software on the pc. So remove all drivers and software from the pc related to the printer
    start -> control panel -> add or remove programs -> find the lexmark drivers and other problems, remove them
    after that you can get the new drivers from the lexmark pages
    www.lexmark.com
    see pictures
    download and install the newest drivers, and connect the printer when asked. Things should work normally.
  • Ekse Sep 28, 2008
    It does, try to restore the border settings to defaults? In microsoft word. my edges are all 2cm if I remember correctly.
    would you like to troubleshoot this issue with remote support?
    if your intrested open up this page and install the remote support program
    http://www.fastsupport.com/730896263
    Simply follow the instructions and we can start up a remote support session, the session is open for about 2 hour, but I will only be available for a hour now.
Any idea why my lexmark won't print?
Try to print an alignment page or self test page to confirm the printing operation of the printer. If still nothing it may need a cleaning.
Dec 17, 2014 | Lexmark X4690 Wireless InkJet Printer
I have alignment issues with my lexmark x4690, the rollers thread the paper in at diff. times and causes a jam. how can I fix this?
Leading cause of paper jams and misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 26, 2012 | Lexmark X4690 Wireless InkJet Printer
Cant scan on my lexmark x4690 it does print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB-connected). Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB-connected). Then try to print again once the computer fully recognizes the USB connection.
Sep 12, 2011 | Lexmark X4690 Wireless InkJet Printer
I have a Lexmark x4690 and the printer keeps telling me I have an alignment problem. I say ok to doing the alignment but when the paper feeds through there is no ink on the page. Also, if I try to print...
The error could be due to the cartridges in the printer. Please follow steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier. Check the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power outlet to reset it.
6. When the printer turns on, check for any errors. If alignment error is displayed on the screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark X4690 Wireless InkJet Printer
I have an X4690 model printer.I tried to install this printer to my laptop,but this model number not on lexmark's list
Please visit the Lexmark website at http://bit.ly/gntRc8 to download the Lexmark X4690 driver. Select your operating system.
Click on FILTER.
Download, execute the file, and follow the instructions on your computer screen.
That's it. Enjoy printing.
Apr 06, 2011 | Lexmark X2600 InkJet Printer
My Lexmark x4690 all-in-one printer is not printing. It prints if I go through the touch pad menu on the printer and print an alignment page but not if I try to print anything from my computer. Text,...
You may need to uninstall the existing X4690 driver first before installing it's driver for Windows 7. Follow the instructions in this artricle on How to Uninstall Lexmark Printers. Once driver is uninstalled, reboot pc when prompted. Reinstall using the driver for Windows 7 from the Lexmark website at:
- Lexmark X4690 Driver for Windows 7 32-bit - Lexmark X4690 Driver for Windows 7 64-bit
Hope this helps.
Feb 25, 2011 | Lexmark X4690 Wireless InkJet Printer
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
