Question about Palm Treo 500 Centro
HotSync Problem!! every min hotsync goes up by itself and it wont let my exit out to do other stuff with my phone and how the hotsync page is just up there and i dont kno what to do
    Guru:
  • 1,049 Answers
You have at least one application that is attempting a serial connection with the PC and is triggering hotsync instead. Many palm apps that allow live updating to your device when cradled or over blue-tooth can cause this type of error. I would take inventory of any software you added recently to your device or port settings you may have changed, especially regarding direct connect and cradle settings.
Posted on Oct 06, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Palm m100 hotsync problem
A hard reset will most likely work, but make sure to back up using a third party application.
Nov 10, 2009 | Palm M100
During hotsync, data wont transfer from Computer to palm
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Mar 31, 2009 | Palm Tungsten E2 Handheld
Palm Centro AT&T got wet;
http://www.fixya.com/support/r3771170-phone_water_damage
Jan 24, 2009 | Palm Treo 500 Centro
Cannot hotsync palm t/x. will either reboot itself or will not come back on. PDA was charged over 24 hours before hotsync attempted.
was your hotsync previously working and it suddently got corrupted somehow or is it your first time hooking it up?
Oct 08, 2008 | Computers & Internet
HELP ME WITH MY PALM CENTRO
I am having the same problem.
Aug 25, 2008 | Palm Treo 500 Centro
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Palm Treo 500 Centro Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
