Toshiba TV no power and all you can hear is click click when you plug into the outlet.Thanks.
  • 927 Answers
Good Day;
Sounds like you have a short, more than likely the Convergence IC's. Call factory rep.
Good Luck, big IRISH.
Posted on Sep 28, 2008
Not able to turn on the TV after hearing some clicking sound. please assist on what should I do, how to repair. many thank
See if you can find a fuse on the back near the power cable where it connects to the TV. It sounds like the fuse might have "popped". If it is good, see if the TV is showing a blinking light (probably on the power button) which will indicate an error code. Finally, unplug the TV from everything (cable, power, DVD, etc..) and wait for 15 minutes to see if it will reset incase a thermal issue is occuring. Also check your AC outlet by plugging something that you know works into it to see if the power is dead at the outlet. Plug TV back in and see if powers up with nothing connected to it. Lastly, check your manual to see if there is a base-reset button on the back somewhere to reset it back to factory default settings incase something has locked up your initiation processes.
Hope that helps some!
Stan
May 29, 2014 | Toshiba 42wl55e Flat Panel Tv
Have vizio vp50 part#1014350022 went to turn it on and nothing no lite sound or anything.Tried the reset nothing any ideas. thank you
The first thing to check is if your power outlets have surge protector breakers. Try plugging in another simple appliance like a lamp into the outlet and make sure the outlet has power.
If the outlet is fine try plugging in the TV and listening very carefully from the back of the TV for a subtle click noise. The power supply has a mechanical relay that switches when the TV receives power. If you can not hear the click and there are no stand by or power lights illuminated then you likely have a power supply problem. This could range from a blown fuse to a bad capacitor up to a burnt out power regulator. Anything more serious than those problems may warrant simply replacing the whole power supply. Depending on your TV that board could cost anywhere from $50-$175. The power supply can be tested using a multimeter to determine if it is the source of the problem but this should not be attempted unless you have some electroics repair training and are aware of the dangers involved in working on high voltage electronics.
Dec 23, 2013 | V, Inc. Vizio P50HD Plasma Television
SONY BRAVIA KDL-46S2000 NOT TURNING ON
Look for loose contacts in power outlet. Try the TV on some other power outlet. There could also be a problem with the power cord.
Aug 05, 2012 | Televison & Video
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
We have a toshiba projection tv model #57hx93, we lost power to house, when power came back on the tv will not power up, have checked breaker and reset still will not turn on, any ideas?
Oh goodness... this just happened to me!!! There was a power outage on my block. After the power was restored my toshiba model #57HX93 won't turn on but I can hear a clicking noise when I plug it in the outlet.
May 14, 2011 | Toshiba Televison & Video
When unit is plugged into a power outlet, the power indicator lights up for about two or three seconds, then a click is heard and the indicator goes off. The indicator immediatly light up again then after...
The problem is the television is not getting the correct amount of power, so a breaker inside the tv is flipping, thats the click you hear, the problem could be within the TV itself or the outlet it is plugged into, try plugging the TV into another outlet and if the problem persists you will have to call either the store you bought it from or the manufacturer.
Mar 01, 2011 | Samsung LNT3242H Television
MY Toshiba 65H93 doesn't come on.When I press the power button nothing happen.But when I unplug the it from the AC outlet and plug it back into the AC Outlet I here a clicking sound, but the set still...
Same here! Just happened yesterday after we had a power outage in the neighborhood and when the power to the neighborhood was restored my 65H93 would not power on with the remote or the power button on the front of the TV. I get the same clicking sound when unplugging and or pushing the reset on the front of the TV. I also see a red light come on inside for about a half a second after hitting reset or unplug/replugging it in. I'm thinking it has something to do with the standby circuit not coming on due to some problem with the power supply/circuit board?
Have you found out anything yet? I'll let you know if I find out anything also.
Thanks
Jul 18, 2010 | Toshiba 65H93 65" Rear Projection...
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
May 10, 2009 | Sony KV-32FS12 32" TV
Toshiba MW24F51 has no power
GO TO POWER SUPPLY SECTION, check out for fuses blown or any part that burnt, hopefully is the fuse , if not then need to replace the whole power supply unit. good luck , AJ
May 07, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
